clifford saber II in 01 dodge ram door lc
thumper74
Posted: May 27, 2003 at 12:28 AM / IP Logged
Can someone please help. i am stuck on the finals os a clifford saber II i have had this alarm for years but never installed it mainly due to the fact i damaged the owners manual beyond recognition. so i just put it away. Ok anyways i installed it in a 01 dodge ram 1500 . i am stuck on the door locks i have tried everything i can think of..i tapped the org/violet and pnk/vlt= nothing, i tested the switches 12 v at wires when triggered. alarm triggers lock/unlock produce .5 volts when armed/disarmed. was told about the central timer wires but can't find them. i tried relays, kept blowing fuses. please can someone help........
donny bryant
antioch, ca
Moderator - Posts: 12,488
Posted: May 27, 2003 at 5:29 AM / IP Logged
  • POWER LOCK|ORANGE / purple *1    |5wire|     driver door harness
  •    POWER UNLOCK|pink/purple *1      |5wire|          driver door harness
Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
