Envoy XL Accessory 2 Wire?
jcp0575
Member - Posts: 8
Posted: March 18, 2016 at 10:58 PM / IP Logged Link to Post Post Reply Quote jcp0575
I have a 2006 GMC Envoy XL Denali, using a Compustar FT-7000as Remote Start/ Alarm w/ Blade-AL. On the main harness I have all connections made, but on the vehicle, I still have an accessory #2 that I have not touched yet, but there are no wires left on the CN1 connecter left to hook up to this. Im already using all 8 wires from the Compustar CN1 connector for(2)12v Power/ Ground/ Ign 1 & 2/ Acc #1/ Starter/ + Parking Lights. What would I need to do to power that Acc #2 wire on the vehicle during remote Start?
Platinum - Posts: 7,787
Posted: March 19, 2016 at 6:00 AM / IP Logged Link to Post Post Reply Quote kreg357
You are in luck, as the FT7000-AS makes this somewhat easy by having a (-) 250mA Accessory output all set to go at plug
CN5 Pin 20.  You will need a 30/40 Amp SPDT relay with an inline fuse.  Here is the wiring :
Relay Pin 85 to CN5-20
Relay Pins 86 and 87 to +12V constant through the fuse with a 25 Amp fuse
Relay Pin 30 to vehicles Brown Accessory2 wire
jcp0575
Member - Posts: 8
Posted: March 19, 2016 at 12:50 PM / IP Logged Link to Post Post Reply Quote jcp0575
Thank you, I love this site, I received a lot of help for each install i've done in the past on my trucks. I cant just leave anything I do as just basic, that why I turn to you guys. I try to buy the best and install as many accessories as I can, RPS Touch, EZGO, 2W901R-SS Remote, Battery backup, (2) DEI535T Window Up/ Down, OP500 Programmer, etc. etc... I'm in Pa so hopefully it warms up as I'm dying to get to this. Thanks again for all your help.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
