Newbie, wiring subs to amp
rbelott
Posted: March 26, 2016 at 10:21 PM / IP Logged Link to Post Post Reply Quote rbelott
I need help figuring out how to wire my subs to my sub box and from the sub box to my amp. I have a Kenwood KAC- 9106D mono amp, two Rockford Fosgate P2D-4 10 inch 4 ohm subs, and a Atrend Bbox A-202-10p. I have looked at both of the DVC 2 ohm and 4 ohm wiring diagrams but my sub box has two spring loaded terminals one for each sub. Do I use both terminals one for each sub or just one terminal like the diagrams shows. Also my amp has 2 postive and 2 negative speaker terminals. Any help would be greatly appreciated.
rs specialist
Copper - Posts: 175
Posted: March 28, 2016 at 11:26 AM / IP Logged Link to Post Post Reply Quote rs specialist
You have 2 dual 4 subs that would generally be wired at either 4 or 1 ohm at the amp. the amp is only 2 ohm stable. I would wire them at 4 ohm.
http://www.rockfordfosgate.com/products/details/p2d4-10 click on the wiring wizard and follow diagram #4   take the positive and negative from each woofer to the terminals on the box then take those and run them to the positive and negative of the amp. You can use 1 positive and 1 negative on the amp for each sub since they are on the same terminal internally.
the12volt
Administrator - Posts: 3,959
rbelott
Posted: March 28, 2016 at 7:18 PM / IP Logged Link to Post Post Reply Quote rbelott
Thank-you for the help.
