5706v, dball2, and 06 Silverado dmax auto start
mattearly
Posted: March 29, 2016 at 6:49 PM / IP Logged Link to Post Post Reply Quote mattearly
Hi everyone! I've been using this forum here and there for many a things however I'm to a point where I can't seem to Google up a solution to my problem. My problem is when my viper module is connected to the 6 and 10 pin connectors the unit will start my pickup and regardless of what I do it won't turn off unless I unplug either one or both of those connectors. The viper unit isn't completely hooked up (missing a couple of wires on the 24-pin harness), but it is connected to the dball2 which is properly flashed (did it myself). The devices all worked up to a point, after it just does this. I could lock/unlock the doors change to valet mode etc. The control center no longer will flash a blue light (I checked the wire to the viper unit for continuity) and I'm stuck! Any help would be greatly appreciated! The unit is wired and doublr checked according to this. This is my first post so I'm ready for any feedback as well. Thanks again
06 Silverado 2500HD Lbz with EFI Live from Idaho Rob
mattearly
Posted: March 31, 2016 at 10:44 PM / IP Logged Link to Post Post Reply Quote mattearly
So I switched to w2w mode and got everything hooked up. Still autostarts when I turn the key to the on position. No communication with remote and no light on the control center. Blown unit maybe?
Platinum - Posts: 7,827
Posted: April 01, 2016 at 5:32 AM / IP Logged Link to Post Post Reply Quote kreg357
Have you tried pulling all the Viper fuses ( especially H1/1 Red ) and waiting around 10 minutes.  That seems to "factory reset": some Vipers systems that are doing strange things.
BTW - that link to the Escalade wiring looked to be W2W besides being for a FLCAN bypass module instead of your DB-ALL2.
mattearly
Posted: April 01, 2016 at 6:54 PM / IP Logged Link to Post Post Reply Quote mattearly
Wow thanks! Got it!!
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
