2015 Nissan Quest Wiring diagram Radio
patamendt45
Posted: April 03, 2016 at 2:23 PM / IP Logged Link to Post Post Reply Quote patamendt45
Hi - Looking for a wiring diagram for all of the harnesses on the back of the radio. Looking specifically for the back up camera wires and the other harnesses functions. Also the micro usb function.
2015 Nissan Quest SV AWD no Bose
Thanks!
tonanzith
Gold - Posts: 603
Posted: May 22, 2016 at 5:20 PM / IP Logged Link to Post Post Reply Quote tonanzith
Radio 12V     yellow or lt. blue     +     radio, white 20 pin plug, pin 19
Radio Ground     (chassis, base audio); black (except base audio)     -     radio, white 20 pin plug, pin 20
Radio Ignition     gray, green, or orange     +     radio, white 20 pin plug, pin 7
Radio Illumination     pink (parking lights); black (dimmer) (base audio)     +,-     radio, white 20 pin plug, pins 9, 8
Factory Amp Turn-on     lt. green     +     radio, white 20 pin plug, pin 1 or white 12 pin plug, pin 9
Power Antenna +     radio, 3 pin plug, pin 1
Left Front Speaker (+/-)     yellow - black, lt. green - yellow, or red - green     +,-     radio, white 20 pin plug, pins 2 - 3 or white 12 pin plug, pins 12 - 6
     On models with amplifier, the speaker wires are white - red at the amplifier in rear cargo floor, brown 23 pin plug, pins 4 - 5. The tweeter wires are blue - black at the amplifier, brown 14 pin plug, pins 1 - 2.
Right Front Speaker (+/-)     black - blue, blue - black, or white - black     +,-     radio, white 20 pin plug, pins 11 - 12 or white 12 pin plug, pins 8 - 2
     On models with amplifier, the speaker wires are white - red at the amplifier in rear cargo floor, brown 23 pin plug, pins 17 - 18. The tweeter wires are brown - yellow at the amplifier, brown 14 pin plug, pins 4 - 3.
Left Rear Speaker (+/-)     lt. blue - lt. green, purple - blue, or blk - wht     +,-     radio, white 20 pin plug, pins 4 - 5 or white 12 pin plug, pins 11 - 5
     On models with amplifier, the door speaker wires are red - white at the amplifier in rear cargo floor, brown 23 pin plug, pins 14 - 1. The quarter panel speaker wires are white - black at the amplifier, brown 23 pin plug, pins 2 - 3.
Right Rear Speaker (+/-)     pink - blue, brown - lt. blue, or brown - yellow     +,-     radio, white 20 pin plug, pins 13 - 14 or white 12 pin plug, pins 7 - 1
     On models with amplifier, the door speaker wires are white - black at the amplifier in rear cargo floor, brown 14 pin plug, pins 14 - 9. The quarter panel speaker wires are white - black at the amplifier, brown 23 pin plug, pins 2 - 3.
Center Channel (+/-)     purple - blue     +,-     amplifier in rear cargo floor, brown 23 pin plug, pins 15 - 16
Subwoofer (+/-)     red - green     +,-     amplifier in rear cargo floor, brown 14 pin plug, pins 13 - 8
Aux. Audio Input Left (+/-)     black - white     +,-     radio, wh 8P plg, pins 1-3; wh 32P plg, pins 28-27
Aux. Audio Input Right (+/-)     red - white     +,-     radio, wh 8P plg, pins 2-3; wh 32P plg, pins 29-27
     The aux. video wires are brown - yellow at the radio, white 16 pin plug, pins 2 - 10.
RSE Video (+/-)     white - black     +,-     radio, white 16 pin plug, pins 8 - 7
     The front display wires are black - white at the radio, white 24 pin plug, pins 12 - 11. The rear view camera wires are black - (shield) at the radio, white 32 pin plug, pins 2 - 1 (display audio) or yellow (or black) - (shield) at the radio, white 16 pin plug, pins 3 - 12 (audio with separate display).
RSE Audio Left (+/-)     pink - blue (headphone audio)     +,-     radio, white 32 pin plug, pins 31 - 32
RSE Audio Right (+/-)     brown - yellow (headphone audio)     +,-     radio, white 32 pin plug, pins 15 - 16
Satellite Radio 12 Volts     green     +     Sat Radio in LR qrtr panel, wht 16 pin plg, pin 12
Satellite Radio Ground     black     -     Sat Radio in LR qrtr panel, wht 16 pin plg, pin 15
Satellite Radio Ignition     pink     +     Sat Radio in LR qrtr panel, wht 16 pin plg, pin 16
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     white - black     +,-     Satellite Radio, white 16 pin plug, pins 2 - 1
Satellite Audio Right (+/-)     green - red     +,-     Satellite Radio, white 16 pin plug, pins 4 - 3
Item     Size     Depth     Location
Headunit     double DIN center of dash
Left Front Speaker     6 x 9 left front door
Left Front Tweeter     2.0 left front dash
Right Front Speaker     6 x 9 right front door
Right Front Tweeter     2.0 right front dash
Left Rear Speaker     6.5 left rear door
Left Rear Tweeter     3.0 left rear door and left rear quarter panel
Right Rear Speaker     6.5 right rear door
Right Rear Tweeter     3.0 right rear door and right rear quarter panel
Center Channel     3.0 top center of dash
Subwoofer     (enclosure) rear cargo floor
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio on some models) left rear quarter panel
Gary Sather
patamendt45
Posted: May 22, 2016 at 6:32 PM / IP Logged Link to Post Post Reply Quote patamendt45
thank you!!!
tonanzith
Gold - Posts: 603
Posted: May 22, 2016 at 6:43 PM / IP Logged Link to Post Post Reply Quote tonanzith
any time :)
Gary Sather
Tuesday, November 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
