Honda civic keyless
csorb
Copper - Posts: 317
Posted: May 28, 2003 at 4:48 PM / IP Logged
I put a sidewinder keyless into an '01 Civic. After I was done with the install, the driver's door - and sometimes the rear passenger door, does not always lock when the other doors do, even when I use the button inside the car. The owner of the car claims that everything worked fine beforehand.
draasch
Gold - Posts: 2,172
Posted: May 29, 2003 at 5:51 AM / IP Logged
the door locks on a K/E is an output.
do you hear any kind of grinding noise coming from the doors when you work the locks?? i have had the honda motors go bad. very common with them.
if the factory switch doesnt work, i would lean towards...it didnt work right when he brought it in to you.
sounds like he has you over a barrell...
let us know what you find out..
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
