2006 Nissan Armada, reverse camera reverse wire
nsmjc
Posted: May 30, 2016 at 10:26 AM / IP Logged Link to Post Post Reply Quote nsmjc
I am trying to locate the reverse wire to activate a backup camera. Baring running a wire to the back of the Armada and hooking into the light itself I would like to hook it up under the dash. Does anyone know which wire it would be?
nsmjc
Posted: May 30, 2016 at 11:58 AM / IP Logged Link to Post Post Reply Quote nsmjc
is there a switched 12vdc wire in the back of a 2006 Nissan Armada.
I am installing a device that only needs to run when the vehicle is running and I wanted to place it in the back of the vehicle however I can only locate constant 12vdc.
Can any one point me to switched 12vdc in the rear of a 2006 Nissan Armada.
It is an O2 generator which is designed to run off a cigarette lighter.
Platinum - Posts: 13,728
Posted: May 30, 2016 at 2:20 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Ignition 1     BLACK/ RED     (+)     IGNITION SWITCH HARNESS
Accessory is Red at Ignition switch harness.
I can think of nowhere in the back of the vehicle.
Reverse Lights     GREEN / WHITE     (+)     IN HARNESS IN DRIVERS KICKPANEL
Friday, August 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
