2013 Honda Accord Front Door Panel Lights?
clementlo
Member - Posts: 6
Posted: June 18, 2016 at 10:18 PM / IP Logged Link to Post Post Reply Quote clementlo
Hi guys long story short. I have an CompuStar Alarm with Blade AL installed. For some reason, the Blade AL kept losing the Trunk Release function.
So today I ask the Alarm guy to hardware the trunk... Yes my trunk is working now.
But now my Driver Side Door Back Lights are all OUT. Other doors are okay. My Power locks and Power Windows are good Because when I get the car, my power seat used to have a GREEN LED that light up when it is set into it's memory position and it didn't... He spend 30 minutes couldn't figure it out... Now I know why, because all the lights are out on the door!   I don't understand, why would he touch the backlights on the door? Does you guy know what wire that causing this? It is only the front door.
I plan to bring it back tomorrow.
clementlo
Member - Posts: 6
Posted: June 18, 2016 at 10:23 PM / IP Logged Link to Post Post Reply Quote clementlo
Oh, anyone that experience with Alarm Installation? Why he mass around with my BackLight on the Door? Is there where the Alarm get it's power??? I don't understand. Hope it didn't fired anything... they are all LEDs...
clementlo
Member - Posts: 6
Posted: June 18, 2016 at 10:45 PM / IP Logged Link to Post Post Reply Quote clementlo
Oh by the way, my Courtesy Door Light is also working in the front door... Aren't the back light use the same wire? I don't understand why my Courtesy Door Light in the lower corner works... But not the backlights...
clementlo
Member - Posts: 6
Posted: June 19, 2016 at 12:03 AM / IP Logged Link to Post Post Reply Quote clementlo
I just found out what happen. I trace the wire from my front door to where the brain of the alarm. Looked like the Alarm installer cut one of the white wire by mistake. He must cut it when he tried to cut the zip tie.
Anyway, after some electronic tapes; I was able to reattached. And it is all working fine now.
Thanks.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
