2012 Kia Sportage Alarm/Remote Start Wiring
lurch228
Silver - Posts: 1,338
Posted: July 30, 2016 at 9:08 PM / IP Logged
Item
Wire Color
Polarity
Wire Location
Photo / Note
12volts
red (40A)
driver kick, white 15 pin plug, pin 11
Starter
red      +      dash fuse box, rear, white 54 pin plug (E), pin 1
Second Starter
white (SS1); WHITE/ black (SS2)      -      start/stop button switch, black 10 pin plug, pins 1, 7
Ignition
blue      +      dash fuse box, rear, white 54 pin plug (E), pin 25
Second Ignition
N/A
Third Ignition
N/A
Accessory
blue      +      dash fuse box, rear, white 54 pin plug (E), pin 31
Second Accessory
white      +      dash fuse box, rear, white 54 pin plug (E), pin 54
Keysense      ORANGE / black      -      key fob holder in center console, white 10 pin plug, pin 9
Power Lock
blue/black      -      dash fuse box, white 54 pin plug (D), pin 40
Power Unlock
gray/black (all doors); yel/blk (driver door only)      -      dash FB, wht 54 pin plg (D), pin 18; rear, wht 54 pin plug (E), pin 49
Lock Motor
orange      5 wire      dash fuse box, white 54 pin plug (D), pin 22
Unlock Motor
green      5 wire      driver kick, gray 24 pin plug, pin 10
Parking Lights+
green (L); yellow (R)      +      dash fuse box, white 54 pin plug (D), pins 34, 51
Parking Lights-
blue      -      headlight switch, white 13 pin plug, pin 1
Hazards      yellow      -      hazard switch, black 6 pin plug, pin 5
Turn Signal(L)      yellow (F); white (R)      +      dash fuse box, wht 24 pin plug (B), pin 5; wht 54 pin plug (D), pin 46
Turn Signal(R)      white (F); WHITE/ black (R)      +      dash fuse box, wht 24 pin plug (B), pin 4; wht 54 pin plug (D), pin 47
Reverse Light      red      +      dash fuse box, white 54 pin plug (D), pin 27
Door Trigger
GREEN/ orange      -      dash fuse box, white 54 pin plug (D), pin 10
Dome Supervision
brown      -      BCM above gas pedal, gray 24 pin plug, pin 5
Trunk/Hatch Pin
white      -      dash fuse box, white 54 pin plug (D), pin 16
Hood Pin
RED / black      -      dash fuse box, white 24 pin plug (B), pin 18
Trunk/Hatch Release
yellow/black (rear handle switch)      -      dash fuse box, white 54 pin plug (D), pin 13
Power Sliding Door      N/A
Factory Alarm Arm
brown (key lock); gray (detect) (Tech Doc 1300)      - and open      dash fuse box, white 54 pin plug (D), pins 14, 7
Factory Alarm Disarm
red (key unlock); gray (detect) (Tech Doc 1300)      both -      dash fuse box, white 54 pin plug (D), pins 36, 7
Disarm No Unlock
(see factory alarm disarm)
Tachometer
white      ac      passenger kick, yellow 24 pin plug, pin 4
Wait to start      N/A
Brake Wire
blue      +      brake switch, white 4 pin plug, pin 1
Parking Brake      gray/orange      -      dash fuse box, wht 54 pin plug (D), pin 15 or wht 24 pin plg (B), pin 19
Horn Trigger
gray      -      driver kick, white 15 pin plug, pin 6
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
MAKE : KIA | MODEL : SPORTAGE (SMART KEY) | YEAR : 2012
* The logo is registered trade mark of Kia Corporate.
Tuesday, September 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
