2007 Equinox, dball2 issues
tctdh11
Member - Posts: 9
Posted: December 13, 2016 at 6:00 AM / IP Logged Link to Post Post Reply Quote tctdh11
Running into some issues while wiring up my pregnant wife's 2007 Equinox LT. Purchased her a Viper 5204, VSM200, and dball2 for her last Christmas and just now getting around to installing it. Funny how much they get on you when it starts snowing out.
Anyways. I've found the wiring diagrams for the vehicle, 5204, and the vsm200. I've found tons of them for the dball2. That's where my issues are arising. I've got the 5204 hooked up completely as far as I can tell. For the life of me (and my dad) cannot get the dball2 to even show any lights.
Curious if any of the installers on here have any notes or wire diagrams for this vehicle or can push me in the right direction.
Thanks in advance!
nrmskate
Member - Posts: 13
Posted: December 13, 2016 at 7:46 AM / IP Logged Link to Post Post Reply Quote nrmskate
Are you using d2d or w2w? if d2d you should only need the main gauge wires in the remote start and the data plug between the two plugged in, in order to have the lights show on the dball2.
tctdh11
Member - Posts: 9
Posted: December 13, 2016 at 7:58 AM / IP Logged Link to Post Post Reply Quote tctdh11
By my understanding the only wires needed in the remote start are positive, geound, and key sense due to the equinox not having typical starter wires. So in theory all I need to hook up on the dball would be the CAN wires, 12v, ignition output, immobilizers, RAPoff and accessory output correct? Other than the obvious d2d, soon and antenna connections.
smokeman1
Platinum - Posts: 1,589
Posted: December 13, 2016 at 8:17 AM / IP Logged Link to Post Post Reply Quote smokeman1
Could you list all of your connection from Viper, DBALL to what and where on the car.
tctdh11
Member - Posts: 9
Posted: December 13, 2016 at 8:22 AM / IP Logged Link to Post Post Reply Quote tctdh11
I'll write it all out how it is sitting currently when I get on my lunch break in an hour and a half. My dad was the one that did most of it trying to be nice and after researching more and more think he got over zealous. Know for sure he hooked up like 8-10 wires at the bcm from the viper. Ie: door lock,unlock, trunk release and horn.
tctdh11
Member - Posts: 9
Posted: December 13, 2016 at 6:46 PM / IP Logged Link to Post Post Reply Quote tctdh11
Main Harness (H1), 6-Pin
___(5204 Wiring Diagram)____   ____(My connection)____
H1/1- Red, (+) 12vdc constant---------Battery
H1/2- Black, (-) Chassis Ground-------Chassis Ground
H1/3- Brown, (+) Siren Output---------Siren positive
H1/4- WHITE/ Brown, Parking isolation--Not used
H1/5- White, Parking light output-----BCM, Brown Plug, White wire
H1/6- Orange, Ground when armed out.--Not used
H2 Harness, 24 Pin
H2/1, pink/white, ign./flex relay cont.-- Not used
H2/2, BLACK/ white, neutral safety input-- Not used
H2/3, blue/white, 2nd Status, rear defog- Not used
H2/4, GREEN/ black, OEM alarm disarm input-Not used
H2/5, RED / white, trunk release output---- BCM, Pink plug,grey wire
H2/6, green, door trigger input---BCM, Pink plug, grey/black
H2/7, BLACK / YELLOW, dome light supervision--BCM, Pink plug, Dk. Blue/white
H2/8, BROWN / black, Horn honk output--BCM, Brown plug, tan wire
H2/9, Dark Blue, Status output------------Not used
H2/10, Pink, Ignition 1 Output------------Not used
H2/11, WHITE/ black AUX 3 output-----------Not used
H2/12, Violet, Door Trigger Input---------Not used
H2/13, WHITE/ violet, AUX 1 output---------Not used
H2/14, violet/black, AUX 2 output---------Not used
H2/15, ORANGE / black, AUX 4 output---------Not used
H2/16, Brown, Brake Shutdown input--BCM, Brown plug, lt. blue wire
H2/17, Grey, Hood Pin Input---------------Hood pin wire
H2/18, violet / YELLOW, Starter Output------Not used
H2/19, Blue, Trunk pin, Instant trigger---Not used
H2/20, Grey/black, Diesel wait to start---Not used
H2/21, WHITE/ blue, remote start/turbo timer--Not used
H2/22, Orange, Accessory Output-----------Not used
H2/23, violet/white, tachometer input-----Not used
H2/24, GREEN / WHITE, OEM alarm arm output--Not used
H3 Harness, 10-pin
H3/1, Pink, Ignition input/output---BCM, Lt. Green plug, Pink wire
H3/2, RED / white, flex relay 12v input-----Not used
H3/3, Orange, Accessory Output---BCM, Lt. Green plug, brown wire
H3/4, violet, starter output--------------Not used
H3/5, green, starter input----------------Not used
H3/6, Red, Ignition/12v input-------------Not used
H3/7, pink/white, (30) flex relay output--Not used
H3/8, pink/black, (87a) flex relay input--Not used
H3/9, RED / black, accessory/starter relay--Not used
H3/10, No Pin, No color, Not used
3-Pin/ Door Lock
1, blue, unlock output---BCM, grey plug, ORANGE / black
2, no pin, no color, not used
3, green, lock output----BCM, grey plug, pink/black
smokeman1
Posted: December 16, 2016 at 9:03 PM / IP Logged Link to Post Post Reply Quote smokeman1
I see a lot of different connection listed on the wiring diagram for the DBALL2 vs your listing above.
Accessory looks to be coming out of the DBALL2 to the ignition switch connector as well as ignition and ignition from the Viper.
Neutral Safety, H2/2, need to be grounded.
Parking light wire to BCM X2 connector...and many other differences.
Unless you and I are looking at different info?
tctdh11
Member - Posts: 9
Posted: December 18, 2016 at 1:11 PM / IP Logged Link to Post Post Reply Quote tctdh11
Got the dball flashed and working but hit another snag. Everything is working as should besides the remote start. Valet light is staying on and have tried every trick to get it to turn off to no success. Have programmed the viper to automatic trans mode and still won't start. Remote makes loud beep with red light and shortly after I can hear what's sounds like a relay in the bcm click on and off 8 times.
smokeman1
Posted: December 18, 2016 at 2:57 PM / IP Logged Link to Post Post Reply Quote smokeman1
Use the following steps to enter or exit Valet Mode:
1. Turn the ignition ON then OFF.
2. Immediately press and release the control button once.
3. The control center LED turns ON when entering and OFF when exiting.
Eight (8) flashes of the Viper...Neutral Safety Shutdown...H2/2. read above post about grounding.
tctdh11
Member - Posts: 9
Posted: December 18, 2016 at 3:09 PM / IP Logged Link to Post Post Reply Quote tctdh11
That doesn't work to get it out of valet. And neither does the door open, lock, unlock, lock trick
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
