enclosure, 12 inch type r
sethwilliams88
Member - Posts: 23
Posted: February 16, 2017 at 11:20 PM / IP Logged Link to Post Post Reply Quote sethwilliams88
Im running 1 12inch type r in a 2.0 cubic sloted inclosure tuned to 35 hz the bass is deep but the higher bass tones sound like crap so i was thinking about buildind a box with an aero port any suggestions i dont know much about them or wat i should tune the next box to that will still hit hard any imput would be greatly appreciated thank you
Seth
DYohn
Platinum - Posts: 10,741
Posted: February 18, 2017 at 10:22 AM / IP Logged Link to Post Post Reply Quote DYohn
What do you mean by "higher bass tones"? What is your crossover setting? A 2-cuft enclosure is a little large for a Type R but it should be fine as long as you are not overdriving it.
sethwilliams88
Member - Posts: 23
Posted: February 18, 2017 at 10:33 AM / IP Logged Link to Post Post Reply Quote sethwilliams88
Some tones hit hard and the rest sound distorted.i was told to make my box as big as i could is that not true?
Seth
whitemike0110
Copper - Posts: 84
Posted: February 18, 2017 at 12:48 PM / IP Logged Link to Post Post Reply Quote whitemike0110
Yeah that's not true. Too much space can be a bad thing. Although subs need their space and enough space is very important. Maybe they meant make it as big as you can because you don't have a ton of space, if your in a car for example. But if you had a Tahoe you wouldn't make a wall for a 12, "making it as large as possible". I used to run 2 type r 10s each in their own ported box. 1.6 ft^3 (feet cubed) tuned at 33hz. They sounded good. What is your crossover set at that may be why highs aren't sounding as good as they could.
Hello.
sethwilliams88
Member - Posts: 23
Posted: February 18, 2017 at 12:51 PM / IP Logged Link to Post Post Reply Quote sethwilliams88
Im sorry im kind of new to all this by crossover do you mean my low pass filter on my amp
Seth
sethwilliams88
Member - Posts: 23
Posted: February 18, 2017 at 1:01 PM / IP Logged Link to Post Post Reply Quote sethwilliams88
My low pass goes from 40hz to 300hz and its set a quarter of the way up
Seth
DYohn
Posted: February 19, 2017 at 10:47 AM / IP Logged Link to Post Post Reply Quote DYohn
A Type R needs about 1.3 CUFT enclosure. Your low pass filter on your amp should be set to no higher than 100Hz. How did you set the gain on the amp?
sethwilliams88
Member - Posts: 23
Posted: February 19, 2017 at 10:55 AM / IP Logged Link to Post Post Reply Quote sethwilliams88
I set my gain to 2volts because thats what the manual for my deck said the rca outputs were
Seth
sethwilliams88
Member - Posts: 23
Posted: February 19, 2017 at 11:02 AM / IP Logged Link to Post Post Reply Quote sethwilliams88
Btw im running a hifonics 1200.1 zues amp at 1 ohm
Seth
soundnsecurity
Gold - Posts: 2,720
Posted: February 20, 2017 at 12:49 PM / IP Logged Link to Post Post Reply Quote soundnsecurity
if you feel like your higher bass tones are lacking then maybe you should think about getting better mids. building a new box that is tunes higher will just shift the peak of the subs output and might help a little bit with your "high bass notes" but it will be at the expense of your lows. 2 cubes ported for a type R is about the maximum i would recommend for those but that is assuming that you dont mean that the entire box including the port is 2 cubes... if thats the case then you may want to make it a bit bigger because type R's like bigger boxes. you could tune as high as 45hz without sacrificing too much low end performance even though i prefer mine tuned below 40hz.
Page of 3
