Getting bass at lower volume levels?
tandrews_ny
Posted: April 17, 2017 at 9:02 AM / IP Logged Link to Post Post Reply Quote tandrews_ny
Hi all,
I have a Kenwood DDX9703S paired with a Memphis mc5.700. I am running a Kicker Comp R 400w on 1ohm. I have adjusted my gains using my TDS 465 o'scope (used 40hz @ 0db for amp and 1khz 0db for speakers). The speakers are 200w alphines in all 4 doors.
The bass generally sounds good at the maximum volumes, but is almost non-existent at lower volumes. Am I missing something? If I set my EQ to Powerful it sounds much punchier. I originally had a Rockford Fosgate but it went bad (had it for many years). I might add the speakers sound wonderful.
Something I'm not sure about and could use some input on, my speaker inputs sit around 700mv, they can go above that but I assume 1x is proper setting for them. However, the sub inputs are 2v at the same volume. I have them at 10x. Is this wrong? Should I use 1x too for that?
Any suggestions on getting this all sorted?
Platinum - Posts: 13,674
Posted: April 17, 2017 at 7:12 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Does the radio have loudness? If so, turn it on.
tandrews_ny
Posted: April 17, 2017 at 7:53 PM / IP Logged Link to Post Post Reply Quote tandrews_ny
It does. I have all that off presently. I don't want the audio louder, i want the bass higher. So right now, if the audio at 29 (max before clipping), I get a significant amount of bass...I want at like 24 there to be bass, right now theres almost nothing.
Posted: April 17, 2017 at 8:16 PM / IP Logged Link to Post Post Reply Quote i am an idiot
That is what the Loudness contour does.
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
