Compustar led, - when armed?
keenxxx
Member - Posts: 27
Posted: December 22, 2017 at 11:04 AM / IP Logged Link to Post Post Reply Quote keenxxx
In the process of installing a Compustar CM 7000. I would like to run 1 super bright blue LED or 2 if a separate ground while armed output is available. Anyone know if the Compustar will handle a single bright blue led or if the system has a ground when armed output? Thanks.
geepherder
Platinum - Posts: 3,668
Posted: December 22, 2017 at 5:17 PM / IP Logged Link to Post Post Reply Quote geepherder
If your load is expected to draw more than 250 mA, use the GWA wire to trigger a relay, then use an appropriate series resistor.
Posted: December 23, 2017 at 4:05 AM / IP Logged Link to Post Post Reply Quote howie ll
Or use a latching relay from the lock wire; a normal relay will drain the battery.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
