Avital Remote Start 4105L
tanna anderson
Posted: February 01, 2018 at 7:31 PM / IP Logged Link to Post Post Reply Quote tanna anderson
I am in search of an installation diagram for a "1 way avital remote start 4105L" I am attempting to install in a 2000 ford explorer limited.
Tanna
Platinum - Posts: 7,827
Posted: February 02, 2018 at 5:19 AM / IP Logged Link to Post Post Reply Quote kreg357
The 4105L comes with a brief Installation Guide that lists it's wires. Many of those will
not be used or needed for your application. Here is a link to the 4105L guide :
https://www.the12volt.com/installbay/file.asp?ID=1307
Here are a few links to basic vehicle wire guides for your 2000 Explorer :
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=18&ModelID=13994
https://www.the12volt.com/installbay/alarmdetail/863.html
Your next step should be making up a wire connection chart and posting it for Forum member
review and comment. You Explorer probably has a transponder chip based ignition immobilizer
system. That will require another module called the bypass module. You can verify the need
for the bypass module by wrapping the ignition key head with about 5 layers of aluminum foil
and then trying to start the vehicle. It shouldn't start if it has the PATS system. You
could also get a $1.99 plain metal ignition key copy from a local hardware store and try
that.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
