Harness for 4-headlights, 4-on low, 4-on high
unfortunately
Member - Posts: 6
Posted: February 11, 2018 at 2:51 PM / IP Logged Link to Post Post Reply Quote unfortunately
Hello,
I have a 1989 Toyota LandCruiser, the model with 4 headlights. It's a 24v model (yes, even the headlights), but I don't think that that will affect the design of the harness. Toyota headlights operate on a switched-ground system. I'd like to revers that to switched power. Current configuration is H1 highs and H4 lows. I'd like to build a harness that allows for all 4 lights to be on during low-beam operation and all 4 lights to be on during high beam operation. I have two Bosch 5-pin relays, and a couple of old harnesses from other projects that I can hack up and repurpose here. However, I'm having trouble wrapping my head around how to configure the harness and relays to achieve what I'm after. Any chance anyone has an idea of how to do this?
Cheers
unfortunately
Member - Posts: 6
Posted: February 11, 2018 at 5:16 PM / IP Logged Link to Post Post Reply Quote unfortunately
Harness for 4-headlights, 4-on low, 4-on high -- posted image.
This is how i've got it imagined. Does that look right?
The lights being installed are LED and can operate in a 9v-32v range. Simplicity and cleanliness of wiring dictates that I'll run them from the balanced 12v fuse block instead of 24v off the high side battery.
unfortunately
Member - Posts: 6
Posted: February 11, 2018 at 5:18 PM / IP Logged Link to Post Post Reply Quote unfortunately
I based this off of the diagram here: https://www.the12volt.com/relays/relaydiagram8.html
unfortunately
Member - Posts: 6
Posted: February 11, 2018 at 6:16 PM / IP Logged Link to Post Post Reply Quote unfortunately
Updated for cleanliness & efficiency.
the12volt
Administrator - Posts: 3,957
Posted: February 12, 2018 at 10:18 AM / IP Logged Link to Post Post Reply Quote the12volt
Your diagram looks good to me for switching 12V+ to each light during high and low.
Harness for 4-headlights, 4-on low, 4-on high -- posted image. the12volt • Support the12volt.com
unfortunately
Member - Posts: 6
Posted: February 13, 2018 at 10:55 AM / IP Logged Link to Post Post Reply Quote unfortunately
Thanks for having a look. Now to build the harness and wire it up. I'm not super confident in my electrical skills, I appreciate the extra set of eyes on my diagram.
unfortunately
Member - Posts: 6
Posted: February 21, 2018 at 9:54 PM / IP Logged Link to Post Post Reply Quote unfortunately
Thanks again, I got the harness built and my new headlights working as expected. Cheers!
the12volt
Posted: February 22, 2018 at 8:11 AM / IP Logged Link to Post Post Reply Quote the12volt
You're welcome. Happy to hear you have it working.
Tuesday, October 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
