New System Installed, But is Ticking / Popping
troye
Member - Posts: 6
Posted: February 28, 2018 at 11:57 AM / IP Logged Link to Post Post Reply Quote troye
It looks like I am making some progress!
I did "most" of the big three upgrade. Two 1/0 grounds from battery (chassis and engine) and added an additional ground to the alternator
Bypassed Metra ground , and sanded off the black paint from the screw of the new ground
Bypassed Metra for power, used 'add a circuit Fuse' with 16 gauge wire
I am going to re-solder the ground and power as I did not do a good job.
Now I have some white noise only when sound is not present - I hooked up a good old alpine deck to test and there is no noise coming from that, so leads me to believe there is an issue with the Kenwood DNX573s, I will try a new deck today.
troye
Member - Posts: 6
Posted: March 07, 2018 at 9:51 PM / IP Logged Link to Post Post Reply Quote troye
Guys thanks for your help! Big3 upgrade completed, some ground modifications, resolder, deck replacement, and all is good! Sounds great!!! Well it is getting there, now I need to tune it. Deciding DSP or no.
