Suzuki Celerio, ACC Circuit?
crazyaxe
Posted: April 18, 2018 at 6:06 AM / IP Logged Link to Post Post Reply Quote crazyaxe
Hello,
I bough a "dash cam" camera, it has 3 wires: +,- and ACC. Where is the ACC circuit in Suzuki Celerio car? I can't find it.
jaybonez
Posted: April 18, 2018 at 9:58 PM / IP Logged Link to Post Post Reply Quote jaybonez
Well i know a very reliable way to get easy and quicker access to the accessory circuit in any vehicle is behind the stereo as the stereo hooks to the accessory circuit just about every time .however I'm not one hundred percent certain that this w be as easy a task with a stock stereo head unit as it would be if the vehicle had an after market stereo head unit installed as mosst head hnits have a label stuck on them inicating which wires in the stereo head unit are for which wires or circuits in the vehicle so this would mean that you simply pull the stereo out of the holder and leaving it hooked up still locate on the label which color wire would be the one hooked to the twelve volt switched and or the ignition and simply follow this wire to the vehicle wiring and wallah you have an access point to hook to the accessory circuit or the ignition ( switched twelve volt ) hope this helps you out good luck let us know how you did on this !
%Pattonz~pleasure~palace%
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
