2005 Kia Sedona, Alarm/Remote Start Wiring
live2wire65
Member - Posts: 6
Posted: April 30, 2018 at 12:59 PM / IP Logged Link to Post Post Reply Quote live2wire65
I am looking for wiring information on alarm and remote start for a '05 Kia Sedona Lx any help would be greatly appreciated.
livewire
wirewise
Moderator - Posts: 489
Posted: April 30, 2018 at 1:01 PM / IP Logged Link to Post Post Reply Quote wirewise
SEDONA      2002-2005
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      N/A
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+) and BLACK/RED (+)      @ IGNITION SWITCH HARNESS
STARTER      BLACK/YELLOW to YELLOW (+)      @ IGNITION SWITCH HARNESS
STARTER 2      N/A
IGNITION 1      WHITE/BLUE to WHITE (+)      @ IGNITION SWITCH HARNESS
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      GREEN (+)      @ IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2      WHITE to BLUE (+)      @ IGNITION SWITCH HARNESS
KEYSENSE      N/A
PARKING LIGHTS ( - )      WHITE/RED (-) or WHITE (-)      @ HEADLIGHT SWITCH
PARKING LIGHTS ( + )      RED/BLACK (+)      IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
POWER LOCK      WHITE/BLACK (TYPE B)      @ PLUG LEFT OF THE STEERING COLUMN
POWER UNLOCK      RED/GREEN (TYPE B)      @ PLUG LEFT OF THE STEERING COLUMN
LOCK MOTOR WIRE      BLUE/RED (5-WIRE TYPE)      IN DRIVERS KICK, at DOOR HARNESS
DOOR TRIGGER      WHITE/RED (-)      TOP OF FUSEBOX
DOMELIGHT SUPERVISION      USE DOOR TRIGGER, Requires Relay
TRUNK RELEASE      N/A
SLIDING POWER DOOR      N/A
HORN      YELLOW/WHITE (-)      @ STEERING COLUMN HARNESS
TACH      GREEN (AC)      @ IGNITION COIL
WAIT TO START LIGHT      N/A
BRAKE      WHITE (+)      @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM      N/A
ANTI-THEFT      N/A
~wirewise~ Verify all wiring with your meter before making any connections!
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
