Get steady Output for turn signals No Relays
3rror
Posted: June 03, 2018 at 10:36 AM / IP Logged Link to Post Post Reply Quote 3rror
Hi,
I am planning to do a headlight project with dynamic turn signals for my 04' LS430.
I did read about relays and capacitors being used in some cars. Saw the diagrams too. But the problem with this car is. It doesn't use a relay to do that. The ECU controls the output. And you have no access to any relays.
I am doing animations with the turn signals by programming it with Arduino. So I need steady output to carry out the process without breaking.
Can I use an external battery to do this ? Or are there any other tricks for this to be madr possible?
Thanks a Lot :D
cpalmer
Copper - Posts: 115
Posted: June 03, 2018 at 9:26 PM / IP Logged Link to Post Post Reply Quote cpalmer
I'm not 100% but I believe that you can find a constant trigger at the steering column.
Thursday, January 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
