2015 Honda Pilot Subs, Cut Mic Wire Alternative?
ramon2001
Member - Posts: 47
Posted: June 08, 2018 at 1:04 PM / IP Logged Link to Post Post Reply Quote ramon2001
Added after amp and subs. Makes loud bumping sounds after closing door. Cut mic wire on the maps lights but now i dont have bluetooth mic. It was yellow wire. Is there better way of doing this? Please help. Your help will be extremely appreciated. Thank you. Tapped into factory sub for hi to low converter.
ramon
Platinum - Posts: 13,717
Posted: June 08, 2018 at 3:00 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If same as 2012, read the following.    https://www.the12volt.com/installbay/forum_posts.asp?tid=130993
ramon2001
Member - Posts: 47
Posted: June 08, 2018 at 5:59 PM / IP Logged Link to Post Post Reply Quote ramon2001
15 is different. The mics are on a board. No red wire on the plug thank you for your assistance. Hope someone comes thru....
ramon
icearrow6
Copper - Posts: 497
Posted: June 12, 2018 at 6:31 PM / IP Logged Link to Post Post Reply Quote icearrow6
Hello Ramon, I believe the noise you are hearing is coming from a system called "Active Noise Canceling" built into the the audio system of some honda vehicles. You can disable this by disconnecting the ANC module located behind and above the glove box. Its a greybox. you will need to remove the glove box to access this area.
KPierson
Platinum - Posts: 3,527
Posted: June 16, 2018 at 1:26 AM / IP Logged Link to Post Post Reply Quote KPierson
Worst case scenario put a switch on the wire and just turn the mic back on when you need it.
Kevin Pierson
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
