Installing Nissan Stereo In Antique Car
sonoman1
Posted: July 14, 2018 at 4:01 PM / IP Logged
I have a Nissan 28185 3RA2A I would like to install in the glove box of an antique car. I know, it's a low-end stereo but I am just looking for a basic AM/FM/CD/Aux with digital tuner to replace a 40 year old analog-tune Pioneer cassette deck that is all dried out. I am limited in height and want a simple, clean look.
I have the Nissan 28185 3RA2A stereo and a Scosche "Nissan reverse car stereo connector" adapter for power and speaker wiring.
When connected to 12V, ground, speakers, and antenna, it won't power up
- What is the third connector (middle) on the back of the radio?
- I have not installed a non-factory radio in years...now they are called "head units". Does this require an external amplifier or additional components?
- Any thoughts on why it won't power up? DMM shows it is getting power to the power wire and it has a good ground.
thanks
sonoman1
Posted: July 14, 2018 at 4:05 PM / IP Logged
Following up on after the Forum Rules prompt,
- the donor car was a 2013 Nissan Sentra, the radio is a 28185-3RA2A stereo and it was sold as not needing any codes
- the target car is a 1966 Mustang. No IC's in the car
I am just looking for a simple AM/FM/CD/Aux installation to replace the old stereo
geepherder
Platinum - Posts: 3,668
Posted: July 14, 2018 at 4:06 PM / IP Logged
You should have 2 power wires. One is constant, the other is switched with the key.
sonoman1
Posted: July 14, 2018 at 4:38 PM / IP Logged
Hi geepherder,
Do both power wires need to be hot? I assume I wire one or the other, but not both. Is that correct? Or do I need to put power on both simultaneously? The red wire on the Schosche NN04RB adapter is "12V ignition switched" and the yellow wire is "12V battery/constant.
I am tied up the rest of today so I cannot get back to it until tomorrow morning
thanks
the12volt
Administrator - Posts: 3,959
Posted: July 14, 2018 at 7:40 PM / IP Logged
Yes, both wires need to be connected. The red needs to be connected to a 12V+ accessory source (on/off with the key) and the yellow needs to be connected to a 12V+ constant source (battery).
Installing Nissan Stereo In Antique Car -- posted image. the12volt • Support the12volt.com
sonoman1
Posted: July 15, 2018 at 12:33 PM / IP Logged
Connected both wires. I forgot about the clock needing constant power
Works great now. Thanks for the tip!
have a great weekend
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
