1999 Acura EL 1.6 Stereo Wiring
teagan2018
Posted: July 31, 2018 at 8:27 PM / IP Logged Link to Post Post Reply Quote teagan2018
Hi I'm looking for a 1999 Acura EL stereo wiring diagram! Thanks
Platinum - Posts: 13,726
Posted: July 31, 2018 at 8:37 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What are you trying to do?
http://metraonline.com/part/70-1721
teagan2018
Posted: July 31, 2018 at 8:40 PM / IP Logged Link to Post Post Reply Quote teagan2018
Im looking for one of those charts where it says what each wire does.
teagan2018
Posted: July 31, 2018 at 8:42 PM / IP Logged Link to Post Post Reply Quote teagan2018
When I plug my deck in it doesn't work. Trying to find out which wires are for the power and ground, etc.
geepherder
Platinum - Posts: 3,668
Posted: August 01, 2018 at 8:14 AM / IP Logged Link to Post Post Reply Quote geepherder
try this:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=13192
Posted: August 01, 2018 at 8:21 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Directechs has no info on this vehicle. They do have the following for the CL
Radio 12V      white/yellow      +      radio
Radio Ground      black      -      radio
Radio Ignition      white/red      +      radio
Radio Illumination      red/black      +      radio
teagan2018
Posted: August 01, 2018 at 3:41 PM / IP Logged Link to Post Post Reply Quote teagan2018
It doesn't have a white/yellow wire, white/red or a red/black.
the12volt
Administrator - Posts: 3,959
Posted: August 01, 2018 at 3:50 PM / IP Logged Link to Post Post Reply Quote the12volt
teagan2018, please re-read his post. That wiring is for a CL, not an EL, but it may have been the same, hence him giving it to you.
Are you plugging in the factory radio or an aftermarket radio with an adapter harness? Also, have you checked all the fuses inside the vehicle and under the hood?
1999 Acura EL 1.6 Stereo Wiring -- posted image. the12volt • Support the12volt.com
teagan2018
Posted: August 01, 2018 at 3:55 PM / IP Logged Link to Post Post Reply Quote teagan2018
Yes I read his post and I don't think they are similar because those wires I do not have in my car. I am trying to get my factory stereo to work but when I plug it in it doesn't turn on. I am about to go to the local audio shop and buy a adapter harness for a aftermarket stereo I have around.
I had cut some wires to try and do it without a wire harness but I had no idea what I was doing and couldn't find a diagram that tells me which wire is for which so I crimped the cut ones back together.
I checked the fuse inside the car. Didn't know there was any under the hood so I'll check right now.
geepherder
Posted: August 01, 2018 at 8:22 PM / IP Logged Link to Post Post Reply Quote geepherder
The EL is on the same platform as the Honda Civic. The CL is built on the Honda Accord platform.
