Compustar CS6900-AS in a 2004 Tundra Double Cab
troygattis
Posted: August 14, 2018 at 6:19 PM / IP Logged Link to Post Post Reply Quote troygattis
First off, I've been researching and reading this forum for a few days/nights...You guys rock!! Tons of info and helpful tips for almost everything.
I recently purchased a 2004 Tundra SR5 Double Cab, it did not come with a factory security system and fiddling with a key to unlock the truck while trying to load up a couple of attack Shih-tzus is a little bit of a pain, (I also have a 2002 Tundra SR5 Limited Access Cab and it had the factory security/keyless entry) I started looking at keyless entry and remote start systems.This past weekend I was discussing the differences and my girlfriend informed me she had purchased the CS6900-AS bundle for me as birthday present. So after spending too many hours reading and searching I have a few questions.
Will I have to have the CM-600-AS "flashed" before it will function with the basic options? (remote start,lock/unlock, shock sensor,siren)
Will it allow me to roll windows up or down from the remote? In the event I leave a window open and it starts raining.
What other items might I need to perform this function?
There is a tonneau(sp?) cover on the truck, I'd like to arm the tailgate to trigger the alarm, is there any special precautions for using a standard push pin trigger?
I'm very comfortable doing this myself, have plenty of experience with stereo installs and such, so working around the airbag stuff is no issue...I have a DMM and know how to use it, all connections will be soldered, heat shrinked or crimped and sealed as needed. Any advice is appreciated. Thanks!!!
If I can't find it myself, I ask...
silvercivicsir
Copper - Posts: 416
Posted: August 15, 2018 at 4:28 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
no flash required.. it will work out of the box. (Assuming American truck with no immo)
No to window roll up, unless you want to buy a DEI 529T
As for the Tailgate, the hardest part will install the pin trigger / running the wire.. a mercury switch might be a better idea
troygattis
Posted: August 15, 2018 at 6:08 PM / IP Logged Link to Post Post Reply Quote troygattis
Thanks Sir !! I just looked over the DEI module, looks like a 535T will be what I want to go with (2 actually since it's 4 door) that way I can roll them up or down either with or without the alarm set.
As far as running a wire from the pin switch, I don't mind doing that, I'm more concerned with corrosion on the pin body preventing a trigger. I'm thinking I may be able to purchase the factory door switch(they are rubber surrounded) and mount it in a position that will have contact to open the circuit when the tailgate is closed.
