radio installation
fattyarbuckle
Posted: June 04, 2003 at 9:31 PM / IP Logged
radio installation -- posted image.
I have a 1990 ford ranger pickup and the radio/cassette does not work!  My son just gave me the radio/cassette out of his 1996 Thunderbird.  The wiring harness is not the same and I'm wondering if anyone out there knows how I might wire the thunderbird radio to make it work in my ranger??  If I could get a diagram of the wiring harness pin out or the pinout for his radio I know I could probably wire it myself.  I believe his came with the standard ford Amp that is mounted in the trunk.   Any help that anyone could give me would be grately appreciated.
The Fat One
esmith69
Gold - Posts: 1,511
Posted: June 04, 2003 at 9:38 PM / IP Logged
As you've already noticed, the thunderbirds come with a factory amplifier.  The ford ranger on the other hand does not.  Unfortunately for your situation, it most likely means that you cannot use the thunderbird head unit in the ranger, as it only has low-level (unamplified) outputs.  In order to directly power speakers, you need a head unit that has a built-in amplifier, such as the one that came with your ranger that does not work.  As with many car stereo things, theoretically it COULD be done but you'd need a line driver which will run you at least 75 bucks for a good one, and even then the hookup is going to be very tricky.  You'd be MUCH better off with an aftermarket tape deck for 100 bucks more--it would work perfectly in your ranger.
Ethan
Donate to the12volt.com
