2017 Prius Prime, Constant and Switched Power
nytosc
Posted: November 05, 2018 at 2:18 PM / IP Logged Link to Post Post Reply Quote nytosc
Hello everyone,
Newb here (was a 12v installer way back in college and would use this site for diagrams and what not). I went to install a dashcam on my 2017 Prius Prime (not the standard Prius) and am having all sorts of trouble finding switched power and ignition. Does anyone here have any experience in finding such? I pinned out the fuse box, found circuits that looked good, but after the car sits for a certain period of time it seems like the circuits change?
Platinum - Posts: 13,726
Posted: November 05, 2018 at 7:09 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      White (50A)      +      Dash Fuse Box, white 1 pin plug (3L), pin 1
Ground      (chassis ground)
Starter      Black      +      Hybrid Vehicle Control ECU behind glove box, black 54 pin plug, pin 4
Ignition      Violet      +      Dash Fuse Box, white 32 pin plug (3F), pin 13
Accessory      Red      +      Dash Fuse Box, rear, white 56 pin plug (3A), pin 30
Posted: November 05, 2018 at 7:10 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio 12V      Lt. Blue      +      Radio, white 10 pin plug, pin 4
Radio Ground      Lavender/Brown      -      Radio, white 10 pin plug, pin 7
Radio Ignition      Gray      +      Radio, white 10 pin plug, pin 3
nytosc
Posted: November 05, 2018 at 7:28 PM / IP Logged Link to Post Post Reply Quote nytosc
Thank you for this! May I ask where you are able to find this information? I assume "ignition" and "accessory" are the same as switched power?
I'd love to be able to find the actual OEM schematics- any tips where I can find that level of detail?
