2005 Dodge Caravan Accessory Wire?
sand33p_sidhu
Member - Posts: 25
Posted: November 13, 2018 at 10:43 PM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
Greetings!
I installed a remote start in 2005 Dodge Caravan as per wiring schematic, there is no accessory wire for some reason and upon remote start, heater blower doesn't come on, any advise? any help will be much appreciated.
Thank You
geepherder
Platinum - Posts: 3,668
Posted: November 13, 2018 at 11:34 PM / IP Logged Link to Post Post Reply Quote geepherder
If you can't find the right wire in the ignition harness using a multimeter, it looks like you can ground the blower motor relay with the status/ground-while-running wire (or negative ignition wire). Depending on the rating of the status (GWR) wire, you may want to use a relay just to be safe since it'll trigger two relays (front and rear blower):
https://www.the12volt.com/relays/relaydiagram46.html
Pull up a diagram here (bookmark):
www.bbbind.com/free-tsb
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=112247
Verify with a meter, but it looks like pin 30 in the 49 pin at the front control module (underhood fuse box) has the wire you need to ground.
iskidoo
Silver - Posts: 1,047
Posted: November 15, 2018 at 1:21 AM / IP Logged Link to Post Post Reply Quote iskidoo
Did you diode isolate the 2nd starter wire in your relay setup?
29358_CARAVAN_DIAGRAM
Steve G
sand33p_sidhu
Member - Posts: 25
Posted: November 19, 2018 at 4:21 PM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
Yes starter wire is isolated, otherwise it would blow the fuse right away!
