Hornet 530T - Window Auto System - wiring
mail2neil
Posted: June 05, 2003 at 8:12 AM / IP Logged
Hi Guys,
I am a newbie, so, first off, Hi.., I hope to get to know a lot of you in the future.
I realise  that I am probably more than pushing my luck (as a newbie)...., but..., I have just purchased a Hornet 530T for my Rover MGF.
I have looked at some previous posts and realised that there is a big skill set out there..., so, if someone is willing, I was hoping that they might be able to tell/show me how to wire up the 530T when it arrives?
I have a copy of the wiring diagram for the window lift on my MGF: -
http://www.mgfvvc.freeservers.com/custom.html
Does this help?
Any help, very much appreciated..
Neil..
Car-Stuff
Member - Posts: 26
Posted: June 05, 2003 at 3:59 PM / IP Logged
Does the MGF close the windows automaticallly when holding the door lock over in the lock position?? I dont think rovers do this.
IF not, you will need to add a window closing module to the orange wire of the alarm or one of the output channels.
The info below should assist:- I have not used it so  - dont blame me if it's not spot on...
Nick
MGF 1996
|              12V|                    |   |                            |
|          STARTER|BLACK/ white         |   |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|BLACK / YELLOW        |   |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|                    |   |                            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|pink                |5wi|alarm under centre console  |
|     POWER UNLOCK|orange              |5wi|alarm under centre console  |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|grn/wht & grn/red   |   |alarm under centre console  |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|violet/white        |-  |alarm under centre console  |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|violet/red          |   |alarm under centre console  |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ white         |   |left plug @ instrument clust|
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|                    |   |                            |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|                    |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
mail2neil
Posted: June 06, 2003 at 8:19 AM / IP Logged
No,
Currently when alarmed / locked, then windows do nothing. What I would like to acheive is to get the windows to power up when the alarm is clicked on.
Thanks for the input on the wiring.., I will have to check the colours at the w/e..
The trouble is, I don't really even know where to start. It may be better for me to approach this when the item has arrived, but I thought there may be someone with 530 knowledge that could scribble the wiring needed on the diagram at the link above..
Neil..
Car-Stuff
Member - Posts: 26
Posted: June 06, 2003 at 11:01 AM / IP Logged
e mail me when you get the unit and i will assist further.
nick
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
