2010-13 Toyota Corolla S 80-bit G-Key Remote Start Wiring
irish charm
Member - Posts: 18
Posted: November 26, 2018 at 9:44 PM / IP Logged Link to Post Post Reply Quote irish charm
Hi All,
Looking for the remote start wiring for a USDM 2010, 2011, 2012, and 2013 Toyota Corolla S with 80-bit, G-Key. I’ve searched Fortin, Flashlogic, Omega, and iDataLink and I’m getting conflicting results on wires, colors, pins, and locations.
Thanks!
Alan
tonanzith
Gold - Posts: 593
Posted: December 08, 2018 at 9:44 PM / IP Logged Link to Post Post Reply Quote tonanzith
2013 Toyota Corolla (G Key) - North America
              Item
Wire Color
Polarity
Wire Location
12 Volts
white (120A)
dash fuse box, white 1 pin plug (2G), pin 1
Second 12 Volts
blue (30A) (XRS model only)
ignition switch, white 8 pin plug, pin 7
Ground
(chassis ground)
Starter
black (USA/CAN made); white (JPN made)
ignition switch, white 8 pin plug, pin 8
Second Starter
white (XRS model only)
ignition switch, white 8 pin plug, pin 1
Ignition
brown (USA/CAN made); gray (JPN made)
ignition switch, white 8 pin plug, pin 6
Second Ignition
green (USA/CAN made); white (JPN made)
ignition switch, white 8 pin plug, pin 4
Accessory
gray (USA/CAN made); black (JPN made)
ignition switch, white 8 pin plug, pin 3
Keysense
blue
key switch, white 2 pin plug, pin 1
CAN Bus High
lt. green
data
data link connector, white 16 pin plug, pin 6
        CAN Bus Low
white
data
data link connector, white 16 pin plug, pin 14
              RX DATA
lt. blue (USA/CAN made); pink (JPN made)
data
Transponder Key Amplifier on ignition switch, black 7 pin plug, pin 4
TX DATA
beige (USA/CAN made); green (JPN made)
data
Transponder Key Amplifier on ignition switch, black 7 pin plug, pin 5
IMMO Data
lt. green/black (IMO)
data
ECM next to underhood fuse box, black 60 pin plug, pin 10
IMMO Data 2
pink (IMI)
data
ECM next to underhood fuse box, black 60 pin plug, pin 11
        SIL Data
white
yellow
data
data link connector, white 16 pin plug, pin 7
              Security Light
security light, black 7 pin plug, pin 1 or white 12 pin plug, pin 5
RDA
violet (USA/CAN made); green (JPN made)
data
Body ECU on back of dash fuse box, white 26 pin plug, pin 16
        Power Lock
violet (USA/CAN made); blue (JPN made)
driver kick, white 18 pin plug, pin 16
     Note - Power Lock: This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm arm wire.
      Power Unlock
beige (USA/CAN made); yellow (JPN made)
driver kick, white 18 pin plug, pin 15
     Note - Power Unlock: This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm disarm wire.
             Lock Motor
beige
5 wire
driver kick, white 18 pin plug, pin 8
        Driver Unlock Motor
green (USA/CAN made); lt. green (JPN made)
5 wire
driver kick, white 18 pin plug, pin 17
              Passenger Unlock Motor
green (USA/CAN made); lt. blue (JPN made)
5 wire
dash fuse box, white 18 pin plug (2H), pin 18
Factory Alarm Arm
black (USA/CAN made); lt. blue (JPN made) (driver door key lock)
driver kick, white 18 pin plug, pin 7
Factory Alarm Disarm
pink (driver door key unlock)
double -
driver kick, white 18 pin plug, pin 6
Disarm No Unlock
(use keysense)
Parking Lights
green
dash fuse box, white 30 pin plug (2A), pin 29
Parking Lights -
brown (USA/CAN made); white (JPN made)
headlight switch, white 20 pin plug, pin 18
Hazards
beige (USA/CAN made); gray (JPN made)
hazard switch, gray 4 pin plug, pin 4
Turn Signal (Left)
yellow
dash fuse box, white 30 pin plug (2A), pin 27
Turn Signal (Right)
lt. blue
dash fuse box, white 30 pin plug (2A), pin 28
Headlight
green
headlight switch, white 20 pin plug, pin 20
        Reverse Light
red
dash fuse box, white 30 pin plug (2A), pin 30
        Left Front Door Trigger
violet (USA/CAN made); white (JPN made)
dash fuse box, white 30 pin plug (2A), pin 21
Right Front Door Trigger
beige (USA/CAN made); brown (JPN made) - dash fuse box, white 32 pin plug (2E), pin 20
            Left Rear Door Trigger black (USA/CAN made); lt. blue (JPN made) - driver kick, white 22 pin plug, pin 10
        Right Rear Door Trigger
yellow (USA/CAN made); lt. green (JPN made) - dash fuse box, white 32 pin plug (2E), pin 19
        Dome Light gray (USA/CAN made); white (JPN made) - dash fuse box, white 6 pin plug (2K), pin 2
        Trunk/Hatch Pin lt. green - dash fuse box, white 30 pin plug (2A), pin 7
        Trunk/Hatch Release (use trunk release motor)
        Trunk Release Motor pink (USA/CAN made); red (JPN made) 5 wire driver kick, gray 10 pin plug, pin 8
        Tachometer gray ac data link connector, white 16 pin plug, pin 9
        Clutch Pedal lt. green +
clutch switch, black 2 pin plug, pin 1
        Fuel Pump black (USA/CAN made); lt. green (JPN made) + dash fuse box, white 30 pin plug (2A), pin 8
        Rear Defroster beige (USA/CAN made); black (JPN made) - latched defogger switch, black 10 pin plug, pin 2 or white 40 pin plug, pin 38
        Mirror Defroster (same as rear defroster)
        Left Front Heated Seat beige + latched seat heater switch, black 8 pin plug, pin 6
        Right Front Heated Seat
pink + latched seat heater switch, black 8 pin plug, pin 3
        Speed Sense violet ac
radio, white 20 pin plug, pin 3, white 28 pin plug, pin 17, or gray 5 pin plug, pin 3
        Brake Wire blue +
brake switch or dash fuse box, white 30 pin plug (2A), pin 9
        Parking Brake beige (USA/CAN made); black (JPN made) -
parking brake switch or dash fuse box, white 16 pin plug (2C), pin 5
        Horn Trigger lt. green -
horn switch or dash fuse box, white 32 pin plug (2E), pin 5
        Wipers black (LO); red (HI); blue (ignition) + wiper switch, white 10 pin plug, pins 3, 4, 2
        Left Front Window green - yellow (USA/CAN made); pink - white A power window master switch, white 18 pin plug, pins 3 - (Up/Down) (JPN made) 4
        Right Front Window (Up/Down)
green - brown A driver kick, white or blue 12 pin plug, pins 11 - 6
        Left Rear Window (Up/Down)
red - blue A driver kick, white or blue 12 pin plug, pins 8 - 3
        Right Rear Window black - yellow (USA/CAN made); green - brown (Up/Down) (JPN made)
A driver kick, white or blue 12 pin plug, pins 7 - 12
        Sun Roof (Open/Close) green - blue (function with ignition on only) - map light assembly, black 12 pin plug, pins 4 - 2
        Radio 12V lt. blue + radio, white 10 pin plug, pin 4
        Radio Ground brown - radio, white 10 pin plug, pin 7
        Radio Ignition gray + radio, white 10 pin plug, pin 3
        Radio Illumination green (parking lights); white (dimmer) +,- radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5
        Power Antenna beige + radio, white 10 pin plug, pin 8
        Left Front Speaker (+/- )
pink - violet +,- radio, white 10 pin plug, pins 2 - 6
        Right Front Speaker (+/-)
lt. green - blue +,- radio, white 10 pin plug, pins 1 - 5
        Left Rear Speaker (+/-) black - yellow +,- radio, white 6 pin plug, pins 2 - 6
        Right Rear Speaker (+/-)
red - white +,- radio, white 6 pin plug, pins 1 - 3
        Aux. Audio Input Left white - red +,- radio, white 20 pin plug, pins 17 - 16 or white 28 pin
plug, pins 28 - 27
              Aux. Audio Input Right (+/-)
black - red
radio, white 20 pin plug, pins 15 - 16 or white 28 pin plug, pins 26 - 27
RSE Audio Left (+/-)
black - green (USB audio with navigation)
radio, white 12 pin plug, pins 4 - 5
        RSE Audio Right (+/-)
red - white (USB audio with navigation)
radio, white 12 pin plug, pins 2 - 3
        Satellite Radio 12 Volts
(built into radio)
      What Fits?
   Item
   Size
     Depth
Location
   Headunit
    irregular
        center of dash
   Left Front Speaker
    6.5 or 6.7
        left front door
   Left Front Tweeter
    1.0 or 2.6
        left front door
   Right Front Speaker
    6.5 or 6.7
        right front door
   Right Front Tweeter
    1.0 or 2.6
        right front door
   Left Rear Speaker
    6x9
        left rear deck
   Left Rear Tweeter
    (coaxial)
            Right Rear Speaker
    6x9
        right rear deck
   Right Rear Tweeter
    (coaxial)
          Satellite Radio Tuner
(built into radio)
     right side of trunk (dealer installed)
Gary Sather
Thursday, September 28, 2023 • Copyright © 1999-2023 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
