2018 Hino 155 Alarm Install
desh187
Copper - Posts: 310
Posted: December 11, 2018 at 6:11 PM / IP Logged Link to Post Post Reply Quote desh187
Need alarm wiring info for 2018 Hino 155 and especially keyless as truck has no lock/unlock switch but came with one factory remote.
Any info will be appreciated.Thanks.
geepherder
Platinum - Posts: 3,668
Posted: December 11, 2018 at 7:41 PM / IP Logged Link to Post Post Reply Quote geepherder
If you have the truck there, does the owner's manual tell you where the door lock/unlock relays are located? Do the fuse box covers tell you which relays are which?
If not, you could unplug the door lock actuators and activate the locks while listening for the clicking of the relays. Then just trace your wiring back from there.
Don't forget to plug the actuators back in when you're done.
If all else fails, test the wiring at the actuators while at rest. You may be able to 5-wire them.
aeroian
Posted: December 16, 2018 at 4:58 AM / IP Logged Link to Post Post Reply Quote aeroian
Any luck with getting a hold of that diagram? I also need the Hino wiring colours as well.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
