Do Any of You Use Milwaukee M12 Tools?
Platinum - Posts: 13,728
Posted: December 27, 2018 at 7:41 AM / IP Logged Link to Post Post Reply Quote i am an idiot
If you do, you need to check out the soldering iron. 28 second heat up time with the big chisel tip. I did not time the pencil tip. If you are not using this stuff and you see something in the pawn shop you need to check it out. Same goes for the M18 stuff, but they do not have an 18 volt soldering iron.
Thursday, September 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
