Bulldog RS82B Remote Start, 2012 Volkswagen Eos
mdxray
Posted: January 09, 2019 at 6:18 AM / IP Logged Link to Post Post Reply Quote mdxray
I installed a Bulldog RS82B in my 2012 VW Eos.
The RS seems to not override the need to step on the brake pedal while starting.
When I try to start with the RS, the electrical comes on, but it does not start.
If I disconnect the brakelight switch, the RS works if I put my foot on the brake. Starts right up.
With the brakelight switch hooked up, it will not start. But if I start the car with my key, then turn on the RS, stepping on the brake will shut it off, as it is supposed to.
The RS82B has the anti-theft overide built in that uses a spare key.
Platinum - Posts: 7,783
Posted: January 09, 2019 at 7:27 AM / IP Logged Link to Post Post Reply Quote kreg357
Think you will need a relay to isolate and inject on the Brake wire.
The car must see the Brake signal to crank while the RS82B uses that same signal to shutdown.
A relay could be used to open the RS82B's Brake input wire during cranking and also inject a
+12V signal to the EOS to make it think the brake pedal is depressed during cranking.
I imagine that there is a TechTip on this somewhere...
