2012 Volkswagen Eos Wiring
mdxray
Posted: January 09, 2019 at 6:28 AM / IP Logged Link to Post Post Reply Quote mdxray
installing remote starter. 2012 VW Eos wiring diagrams?
wirewise
Moderator - Posts: 489
Posted: January 09, 2019 at 8:00 AM / IP Logged Link to Post Post Reply Quote wirewise
EOS      2009-2015
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2 INTERFACE FOR REMOTE STARTING
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      BLACK/RED (+), 50 AMP      @ VESCM, (2-PIN PLUG(I), PIN 1, NOTE #2
STARTER      RED/BLACK (+)      @ VESCM, (12-PIN PLUG(G), PIN 1, NOTE #2
STARTER 2      N/A
IGNITION 1      BLACK (+)      @ VESCM, (12-PIN PLUG(G), PIN 11, NOTE #2
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      N/A
ACCESSORY/HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      N/A
PARKING LIGHTS ( + )      GRAY/YELLOW (+), NOTE #6      @ VESCM, (16-PIN PLUG(E), PIN 1, NOTE #2
POWER LOCK      BROWN/GREEN (-) NOTE #3      @ DDCM, (32-PIN PLUG), PIN 32, NOTE #4
POWER UNLOCK      Use LOCK wire, (-) thru a 250 Ohm Resistor
LOCK MOTOR WIRE      YELLOW (+), 5-Wire Type      @ DDCM, (20-PIN PLUG), PIN 13, NOTE #4
DOOR TRIGGER      BROWN/YELLOW (-)      @ DDCM, (20-PIN PLUG), PIN 7, NOTE #4
DOMELIGHT SUPERVISION      RED/PURPLE (-)      @ VESCM, (12-PIN PLUG(B), PIN 11, NOTE #2
TRUNK RELEASE      PURPLE (-), NOTE #8      in DRIVERS KICK PANEL or CSCCM, (8-PIN PLUG), PIN 6, NOTE #5
SLIDING POWER DOOR      N/A
HORN      BLACK/WHITE (+)      @ VESCM, (6-PIN PLUG(J), PIN 6, NOTE #2
TACH      NOTE #9      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      BLACK/RED (+), (TEST with IGNITION KEY ON)      @ VESCM, (16-PIN PLUG(E), PIN 2, NOTE #2
FACTORY ALARM DISARM      NOTE #7      @ DDCM, (20-PIN PLUG), PIN 16, NOTE #4
ANTI-THEFT      VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass Module, for REMOTE STARTING ONLY! Part # DLPK-CANBUS MULTI for REMOTE STARTING and DOOR LOCKS (Resistors for DOOR LOCKS, NOT REQUIRED)
NOTE #2: the VESCM, (Vehicle Electrical System Control Module) is the RELAY BOX, Under the DRIVERS DASH.
NOTE #3: this vehicle uses a 1-WIRE DOOR LOCKING SYSTEM, that Requires Extra Parts for operation. See DIAGRAM. The use of Bypass Module DLPK-CANBUS MULTI will do the ANTI-THEFT and DOOR LOCKS without the use of relays and resistors.
NOTE #4: the DDCM, (Drivers Door Control Module) is located in the DRIVERS DOOR.
NOTE #5: the CSCCM, ( Comfort System Central Control Module) is located behind the GLOVE BOX.
NOTE #6: for the PARKING LIGHT FLASH option, it will be necessary to break the HEADLIGHT Switch OFF wire, BLACK/YELLOW (+), located at the VESCM, (16-PIN PLUG(E), PIN 16.
NOTE #7: to DISARM FACTORY ALARM (if needed) Requires a (-) thru a 250 Ohm Resistor on the GREEN/WHITE (-) wire, requires resistor and relay. TEST this wire while turning the KEY in the DRIVERS DOOR.
NOTE #8: TEST this wire while Opening the TRUNK with the Handle on the REAR of the Vehicle
NOTE #9: when using the TACH wire, use a BROWN/BLACK, BROWN/WHITE, BROWN/PURPLE or ROWN/GRAY, they all test (AC)
~wirewise~ Verify all wiring with your meter before making any connections!
