2007 Dodge Charger, Prestige APS787E
antman1
Copper - Posts: 121
Posted: January 23, 2019 at 8:25 PM / IP Logged Link to Post Post Reply Quote antman1
would anyone be able to assist me? I need to figure out this install and what type of Transponder bypass is needed. Here is the manual for the alarm: https://www.manualslib.com/manual/806483/Prestige-Aps-787e.html
I will be installing it in a 2007 Dodge Charger. Please help me figure this out. I really appreciate it..
Platinum - Posts: 7,827
Posted: January 23, 2019 at 9:36 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is a link to a similar install on a 2006 Charger :
https://www.the12volt.com/installbay/forum_posts.asp?tid=132847
Think I would find an online seller that will flash the bypass module prior to shipment.
My favorite for your car is an ADS AL-CA or FLCAN bypass module flashed with the CH-5
version of firmware. The bypass module install wiring has changed slightly since this
Pictorial was done so follow the latest guide when doing your car.
When you decide on the bypass module we can give you the exact wiring on your APS787E
R/S system.
Thursday, July 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
