2006 Pontiac G6 Remote Start Wiring
mikedz
Posted: January 25, 2019 at 9:32 AM / IP Logged Link to Post Post Reply Quote mikedz
need wiring diagram for a bulldog rs82 remote car starter for a pontiac 2006 g6 thanks
Michael Dziekonski
wirewise
Moderator - Posts: 489
Posted: January 25, 2019 at 10:28 AM / IP Logged Link to Post Post Reply Quote wirewise
PONTIAC G6
MODEL      YEAR(S
G6      2005-2007
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      PONTIAC'S MULTIPLEX IGNITION/TRANSPONDER SYSTEM, See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED/BLACK (+)      BCM, RED 41-PIN PLUG, PIN D1, "C3"
STARTER      See NOTE #1
STARTER 2      N/A
IGNITION 1      PINK (+)      IGNITION SWITCH, GREEN 6-PIN PLUG
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      BROWN (+)      IGNITION SWITCH, GREEN 6-PIN PLUG
ACCESSORY/HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      BROWN/WHITE (-)      @ HEADLIGHT SWITCH or BCM C2, PIN 5, See NOTE #2
PARKING LIGHTS ( + )      BROWN (+)      @ HEADLIGHT SWITCH or BCM, C3, PIN A7, See NOTE #2
POWER LOCK      WHITE (1-Wire System) See NOTE #5      @ BCM, C1, Pin 66, See NOTE #2
POWER UNLOCK      Same wire
LOCK MOTOR WIRE      GRAY/BLACK to GRAY (+)      @ BCM, C3, Pin A5, See NOTE #2
DOOR TRIGGER      See NOTE #3      @ BCM, C1, See NOTE #2
DOMELIGHT SUPERVISION      GRAY (-)      @ BCM, C3, Pin A10, See NOTE #2
TRUNK RELEASE      BROWN/WHITE (-)      @ BCM, C1, PIN 71, See NOTE #2
SLIDING POWER DOOR      N/A
HORN      TAN (-)      @ BCM, C2, PIN 14, See NOTE #2
TACH      See NOTE #4      @ IGNITION CONTROL MODULE
WAIT TO START LIGHT      N/A
BRAKE      WHITE (+)      @ BCM, C1, PIN 24, See NOTE #2
FACTORY ALARM DISARM      LT.GREEN ( - ) NEG . THRU 500OHMS (use a 470 + 33 ohm 1/2watt connected end to end)      DOOR HARNESS IN DRIVERS KICK OR @ BCM,C1, PIN 35, See NOTE #2
ANTI-THEFT      PONTIAC'S MULTIPLEX IGNITION/TRANSPONDER, See NOTE #1
NOTES
NOTE #1: THIS VEHICLE REQUIRES A SPECIAL INTERFACE BYPASS MODULE TO REMOTE START, PART # DBALL2 or XK09 THESE INTERFACES WILL ALSO DO THE KEYLESS ENTRY, ignition delay circuit is needed when installing an RS82, RS1100, or RS1200 and a DBALL2 or XK09 interface in a GM vehicle that has no starter/ crank wire coming from the ignition switch.
NOTE #2: the BCM (Body Control Module) is part of the FUSE/RELAY BOX , on the FRONT PASSENGER SIDE of the CENTER CONSOLE, the connectors are: C1-72pin GRAY Plug, C2-72pin GRAY Plug, C3-41pin RED Plug, and C4-68pin LIGHT GRAY Plug.
NOTE #3: the DRIVERS DOOR is a GRAY/BLACK (-) PIN 51, the PASSENGER DOOR is a TAN/WHITE (-) PIN 72, the DRIVERS REAR DOOR is a LIGHT BLUE/BLACK (-) PIN 54 and the PASSENGER REAR DOOR is a LIGHT GREEN/BLACK (-) PIN 53. When connecting to an ALARM SYSTEM, use all (4) DOOR TRIGGER wires and DIODE ISOLATE
NOTE #4: on the 2.2L engine, use the WHITE or ORANGE wire, on the 3.5L 6-Cylinder engine, use the PURPLE, ORANGE/WHITE or LIGHT BLUE.
NOTE #5: this vehicle uses a 1-Wire DOOR LOCKING SYSTEM that requires a (-)Negative thru a 1500 Ohm Resistor to UNLOCK and a straight (-)Negative to LOCK, some units will also require (2) extra relays
~wirewise~
