2019 Chevrolet Colorado Alarm Wiring
kamikaze4299
Member - Posts: 10
Posted: May 14, 2019 at 5:59 PM / IP Logged Link to Post Post Reply Quote kamikaze4299
Does anybody have the security system wiring diagram for the 2019 Chevy Colorado?
icearrow6
Copper - Posts: 497
Posted: May 16, 2019 at 4:13 PM / IP Logged Link to Post Post Reply Quote icearrow6
2019 Chevrolet Colorado - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     Red/Violet (30A)     +     BCM under driver dash, blue 27 pin plug, pin 4
Second 12 Volts     Red/Lt. Blue (2A only)     +     Ignition Switch, black 6 pin plug, pin 2
Ground     (chassis ground)
Starter     Yellow (for starter kill only)     +     Starter Motor or Underhood Fuse Box, black 50 pin plug (X3), pin 5
Ignition     Violet/Black     +     Ignition Switch, black 6 pin plug, pin 1
CAN Bus High     Lt. Blue     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     White     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus SW     Lt. Green     Data     OBD-Data Link Connector, black 16 pin plug, pin 1
OBD 12 Volts     Red/White (10A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
Power Lock     brown/yellow     -     BCM under driver dash, blue 27 pin plug, pin 19
Power Unlock     brown/white     -     BCM under driver dash, blue 27 pin plug, pin 15
Lock Motor     brown/yellow     5 wire     BCM under driver dash, pink 27 pin plug, pin 4
Driver Unlock Motor     gray     5 wire     BCM under driver dash, pink 27 pin plug, pin 1
Passenger Unlock Motor     gray/lt. green     5 wire     BCM under driver dash, pink 27 pin plug, pin 2
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder and ignition)
Parking Lights     violet/gray (LF); gray/brown (RF); brown/blue (LR); brown/gray (RR)     +     BCM under driver dash, black 26 pin plug, pins 6, 5, 7; brown 26 pin plug, pin 7
Parking Lights -     Lt. Green/Gray     -     Headlight Switch, black 12 pin plug, pin 5
Hazards     lt. green/white     -     BCM under driver dash, blue 27 pin plug, pin 26
Turn Signal (Left)     lt. blue/white (F); gray/yellow (R)     +     BCM under driver dash, brown 26 pin plug, pins 2, 1
Turn Signal (Right)     lt. green/violet (F); white/yellow (R)     +     BCM under driver dash, black 26 pin plug, pins 3, 4
Headlight     white/violet     -     headlight switch, black 12 pin plug, pin 1
AutoLights     lt. green/brown     - (off)     headlight switch, black 12 pin plug, pin 3
Left Front Door Trigger     Gray     -     Driver Window Motor, black 7 pin plug, pin 6
Right Front Door Trigger     gray     -     passenger window switch, black 8 pin plug, pin 8
Left Rear Door Trigger     gray (extended cab); gray (crew cab)     -     BCM under driver dash, pink 27 pin plug, pin 27; LR window switch, black 8 pin plug, pin 2
Right Rear Door Trigger     gray (extended cab); gray (crew cab)     -     BCM under driver dash, gray 26 pin plug, pin 11; RR window switch, black 8 pin plug, pin 2
Dome Light     gray     +     BCM under driver dash, blue 27 pin plug, pin 5
Hood Pin     brown/lt. green     -     BCM under driver dash, black 26 pin plug, pin 24
Tachometer     brown, lt. blue, lt. green, or gray/lt. blue (I-4)     ac     passenger side of engine, black 12 pin plug, pin 1, 2, 3, or 4
Note - Tachometer: On V6 models, use the camshaft position sensor, yellow wire, driver side front of engine, black/blue 3 pin plug, pin 2.
On diesel models, use the camshaft position sensor, yellow/purple wire, passenger side front of engine, black 3 pin plug, pin 3.
Fuel Pump     violet/gray (gasoline); gray (diesel)     +     underhood fuse box, black 50 pin plug (X3), pin 20; black 74 pin plug (X2), pin 6
Horn Trigger     brown/white     -     BCM under driver dash, brown 26 pin plug, pin 19
kamikaze4299
Member - Posts: 10
Posted: May 16, 2019 at 6:49 PM / IP Logged Link to Post Post Reply Quote kamikaze4299
Thank you for posting!
Saturday, June 12, 2021 • Copyright © 1999-2021 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
