05 Nissan Frontier Wiring
fgm3533
Posted: June 14, 2019 at 10:28 AM / IP Logged Link to Post Post Reply Quote fgm3533
I am installing an electric window on my 05 Nissan Frontier. I'm not sure where the 12v ignition wire is located. It is suggested that I tap into that line, instead of the battery, so that the widows will only have power with the key is in the on position. Thank you in advance.
fgm3533
fgm3533
Posted: June 14, 2019 at 10:35 AM / IP Logged Link to Post Post Reply Quote fgm3533
I am installing 4 door actuators on my 05 Nissan Frontier and I have it all connected but I want the parking lights to flash when I lock the doors. The wires with the system is purple but I'm not sure what color the parking light wires on the truck are under the driver side kick plate. I'm assuming that the parking light wires are located somewhere with this large harness. Thank you in advance.
fgm3533
wirewise
Moderator - Posts: 489
Posted: June 14, 2019 at 12:24 PM / IP Logged Link to Post Post Reply Quote wirewise
FRONTIER      2005-2006
KEY      T-HARNESS      IMMOBILIZER
N/A      NIS-3      NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and Extra Ignition Key
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      GREEN (+)      IGNITION SWITCH HARNESS
STARTER      GRAY (+) See NOTE *1      IGNITION SWITCH HARNESS
STARTER 2      LIGHT GREEN (+) See NOTE *1      IGNITION SWITCH HARNESS
IGNITION 1      WHITE/GREEN (+)      IGNITION SWITCH HARNESS
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      RED (+)      IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2      GREEN/YELLOW (+)      IGNITION SWITCH HARNESS
KEYSENSE      N/A
PARKING LIGHTS ( - )      N/A
PARKING LIGHTS ( + )      GRAY (+)      IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
POWER LOCK      LIGHT GREEN to PURPLE (TYPE B)      IN DRIVERS KICK PANEL or BCM, PIN 45, See NOTE *2
POWER UNLOCK      WHITE to LIGHT GREEN (TYPE B)      IN DRIVERS KICK PANEL or BCM, PIN 46, See NOTE *2
LOCK MOTOR WIRE      PURPLE (+)      IN DRIVERS KICK PANEL or BCM, PIN 65, See NOTE *2
DOOR TRIGGER      See NOTE *3      @ BCM, See NOTE *2      13985_FRONTIER_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT
DOMELIGHT SUPERVISION      BROWN (-)      @ BCM, Pin 63, See NOTE *2
TRUNK RELEASE      N/A
SLIDING POWER DOOR      N/A
HORN      BROWN (-)      @ HORN SWITCH in STEERING COLUMN
TACH      Any wire NOT WHITE/GREEN      @ Any FUEL INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      YELLOW (+)      @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM      RED/WHITE to GRAY (-)      IN DRIVERS KICK PANEL or BCM, Pin 7, See NOTE *2
ANTI-THEFT      NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and Extra Ignition Key      @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold.
NOTE *2 the BCM (Body Control Module) is located to the RIGHT of the STEERING COLUMN.
NOTE *3 this vehicle has 4 Door Pin Trigger wires, the DRIVERS Door is a GRAY (-) Pin 47, the PASSENGER Door is a LIGHT GREEN (-) Pin 12, the DRIVERS REAR Door is a PINK (-) Pin 48 and the PASSENGER REAR Door is a BLUE (-) Pin 13. All wires are at the BCM. When connecting to an ALARM SYSTEM, use all 4 DOOR TRIGGER wires and DIODE ISOLATE.
~wirewise~
wirewise
Posted: June 14, 2019 at 12:25 PM / IP Logged Link to Post Post Reply Quote wirewise
https://www.the12volt.com/installbay/vehiclewiring/2/yeard/Nissan.html
~wirewise~
wirewise
Posted: June 14, 2019 at 12:26 PM / IP Logged Link to Post Post Reply Quote wirewise
https://www.the12volt.com/installbay/forum_posts.asp?tid=55115
~wirewise~
fgm3533
Posted: June 14, 2019 at 12:35 PM / IP Logged Link to Post Post Reply Quote fgm3533
Thank you for your reply, please if possible, do you have a picture of this gray wire (parking brake) and for correct location. I am not installing a remote start just need to tap into the parking light wire for my keyless entry system.
The module that I have, its wires that go to the parking wires, are purple and its 2 purple wires.
fgm3533
Platinum - Posts: 13,725
Posted: June 14, 2019 at 4:24 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The Gray wire is in the bundle of wires that run to the back of the vehicle. Remove the door sill from the drivers door. There will be a bundle of wires running front to back. It will be in that bundle.
