2018 Dodge Challenger, Add Two Amplifiers
sparxx513
Copper - Posts: 56
Posted: October 27, 2019 at 1:23 AM / IP Logged Link to Post Post Reply Quote sparxx513
I am trying to add two amps, a sub amp and 4 channel to my Challenger stock radio. Base radio version with no amp. Using a Audio Control LC6i. I am getting no signal from the radio into the main input of the lc6i. Using that for the high level input and summing to other channels, and also using for signal to turn on the lc6i. I also have no sound at the radio when using a test speaker. Do i need load resistors? If so on all outputs of the factory radio? I only have the rear outputs going to the lc6i. Appreciate the help.
Platinum - Posts: 12,488
Posted: October 28, 2019 at 10:17 AM / IP Logged Link to Post Post Reply Quote Velocity Motors
Did you have the jumper for the GTO in the Audio Control LC6i on the ENABLED side of the jumper ? Also, not ALL system are able to use the GTO so if it does not turn on, you will need to use a switched ignition feed to the remote turn on input.
sparxx513
Copper - Posts: 56
Posted: October 28, 2019 at 11:39 AM / IP Logged Link to Post Post Reply Quote sparxx513
Yes GTO is enabled, I have the load resistors coming today. Hopefully that will fix the issue.
