2019 Jeep Cherokee Tip Start, Remote Start?
b18c_ej8
Member - Posts: 7
Posted: November 07, 2019 at 8:05 AM / IP Logged Link to Post Post Reply Quote b18c_ej8
Hey guys I've been out of the remote start game for 10+ years so forgive the stupid question
What's out there for remote start into my 2019 Cherokee Latitude non-pushbutton start?
Would prefer integration with my OEM key but a 2nd remote isn't a deal breaker.
Company car so would prefer a plug and play or as close to plug and play as I can get.
I found some P&P units that go to 2018, but nothing for the latest generation that came out with this 2019 model. Thanks!
Platinum - Posts: 7,827
Posted: November 07, 2019 at 8:39 AM / IP Logged Link to Post Post Reply Quote kreg357
iDatalink ADS AL-CA bypass module can do a Stand Alone RS with your
Jeep using Lock-Lock-Lock on the Factory FOB's. You would need
ADS-AL(RS)-CH12 firmware flashed onto the ADS AL-CA. I don't see
a T-Harness available and for this install you would have to cut
two vehicle wires and add a relay. Here is a link to the install guide :
http://images.idatalink.com/corporate/Content/Manuals/RS-CH12/ADS-AL(RS)-CH12-[ADS-ALCA]-EN_20190905.pdf
This solution uses the KLON process so you would also need an ADS USB cable
and iDatalink WEB site access.
mgoetz74
Silver - Posts: 424
Posted: November 14, 2019 at 3:41 PM / IP Logged Link to Post Post Reply Quote mgoetz74
compustar dc3 with t harness. there are 2 harnesses, one has maybe 4 wire to hook up depending is you care about horn honk or a hood switch (a jeep should have a factory one) the other is all plug n play. STill will need a flashlogic updater and a free login to program it.
http://images.idatalink.com/vehicle-install-guides/Guides/712/596/28357/EN/RSA-CH12-[CM-DC3]-(Jeep_Cherokee_2019_28357)-EN_20191031_104306.pdf
