If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
You might want to wire in a buzzer so you don't accidentally leave the switch on and drain the battery. Or if you only use the cargo lights when the key is on, use an accessory or ignition source for power.
