Viper 5706V, EVO-ALL, 2011 Nissan Xterra Pro-4X Manual Transmission
djbaslt
Posted: November 18, 2019 at 9:32 AM / IP Logged Link to Post Post Reply Quote djbaslt
Hello Everyone
***Sorry for my english I'm french use a google translate***
I need to check my connections because the starter does not work
1-The key has been taken by the Evo-all the light is yellow when I leave
2- The doors do not work lock unlock
3-The truck does have the code following the remote control flash 4 times next problem Transmitter shutdown (or optional push button)
4- Looks like Evo-all does not communicate with the viper
5- For the clutch ?? Relay?
Thanks and really appreciate the help, great community.
I followed the wiring for the connections 2007-2015 Nissan Xterra
https://www.the12volt.com/installbay/forum_posts.asp?tid=107929
I start with the Evo-all
I followed the installation of Fortin.ca
https://cdn02.fortin.ca/download/79231/evo-all_ig_reg_bi_nis-xterra_2008-2015_key_d_79231.pdf
The right firmware has been flashed and the Data Link Protocol option D2D turned on
Only three connections that are not connected because they are dotted I think Evo-All will do with Data-Link
(-)LOCK *******************Not connect to Viper
(-)UNLOCK *************** Not connect to Viper
(-)DRIVER DOOR PIN ** Not connect to Evo-all
(+) Ignition ************** Connect to H3 Pink (+) IGNITION 1 INPUT/OUTPUT
Evo-All is connected to the Viper 5706V via the D2D Data-Link protocol
For the Viper here are my connections
Main Harness, White 6-pin connector
H1 RED ************To Battery GREEN (+) IGNITION SWITCH HARNESS
H1 BLACK (-) ********To CHASSIS GROUND
H1 BROWN (+) *******To SIREN +
H1 WHITE/BROWN ****Not connect
H1 WHITE ************Parking Lights GRAY (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
H1 ORANGE*********** Not connect
Remote Start, White 10-pin heavy gauge connector
H3 RED/BLACK ********To Battery GREEN (+) IGNITION SWITCH HARNESS
H3 PINK/BLACK********Not connect
H3 PINK/WHITE********Not connect
H3 RED**************To Battery GREEN (+) IGNITION SWITCH HARNESS
H3 GREEN************Not connect
H3 VIOLET******************Starter 1 GRAY (+) IGNITION SWITCH HARNESS
H3 ORANGE****************Accessory 2 GREEN/ YELLOW (+) IGNITION SWITCH HARNESS
H3 RED/WHITE********To Battery GREEN (+) IGNITION SWITCH HARNESS
H3 PINK*********************Ignition 1 WHITE/ GREEN (+) IGNITION SWITCH HARNESS
Door Lock, 3-pin connector
H4 BLUE ****Not connect
H4 GREEN **Not connect
H2 PNK/White (-) 200mA Ignition 2 / Flex Output     ****** Not connect
H2 Blue/White (-) 200mA 2nd Status/ Rear Defogger Output ****** Not connect
H2 RED / White (-) 200mA Trunk Release Output ****** Not connect
H2 BLACK / YELLOW     (-) 200mA Dome Light Output ****** Not connect
H2 Dark Blue (-) 200mA Status Output ****** Not connect
H2 WHITE/ Black     (-) 200mA Aux 3 Output   ****** Not connect
H2 WHITE/ Violet     (-) 200mA Aux 1 Output   ****** Not connect
H2 ORANGE / Black     (-) 200mA Aux 4 Output   ****** Not connect
H2 Gray (-) Hood Pin Input   (-) Hood Status Input ***Connect
H2 Blue (-) Trunk Pin/Instant Trigger Input   ****** Not connect
H2 WHITE/ Blue Activation Input ****** Not connect
H2 Violet/White*     Tachometer Input *******Connect with Evo-all ??
H2 BLACK/ White**     (-) Neutral Safety/Parking Brake Input******* Connect with Evo-all??
H2 GREEN/ Black     (-) 200 mA Factory Alarm Disarm Output ****** Not connect
H2 Green* (-) Door Input (-) Door Status Output ********Connect with Evo-all??
H2 BROWN / Black     (-) 200mA Horn Honk Output ****** Not connect
H2 Pink (-) 200mA Ignition 1 Output ****** Not connect
H2 Violet* (+) Door Input ******* Connect with Evo-all??
H2 Violet/Black (-) 200 mA Aux 2 Output ****** Not connect
H2 Brown (+) Brake Shutdown Input   ****** Not connect
H2 Violet / YELLOW     (-) 200mA Starter Output   *******connect to relay for 2 starter******
H2 Gray/Black (-) Diesel Wait to Start Input ****** Not connect
H2 Orange (-) 200 mA Accessory Output ****** Not connect
H2 GREEN / WHITE     (-) 200mA Factory Alarm Arm Output     ****** Not connect
Relay for 2 starter
86 to Violet / YELLOW
87 and 85 to 12 volt
30 to Starter 2 LIGHT GREEN (+) IGNITION SWITCH HARNESS
I know something is not working
Thank you
Djbaslt
djbaslt
Posted: November 18, 2019 at 7:54 PM / IP Logged Link to Post Post Reply Quote djbaslt
Hi
I set my problem 2- The doors do not work lock unlock
I made all the connections of the plan Evo-all
lock and unlock works on the remote control of the viper
(-)LOCK *******************connect to Viper
(-)UNLOCK *************** connect to Viper
(-)DRIVER DOOR PIN ** connect to Evo-all
but the remote starter does not work
any help would be very appreciated
Djbaslt
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
