2019 Mazda CX-5, Remote Start, Parking Lights
chev104275
Gold - Posts: 1,436
Posted: January 23, 2020 at 7:58 AM / IP Logged Link to Post Post Reply Quote chev104275
Has anyone done one of these ?   It looks pretty straight forward except for the Parking lights. I'm not sure I like the idea disassembling the switch to make the lights work.   Anyone tried the hazards ?
Thanks Joe
silvercivicsir
Copper - Posts: 416
Posted: January 23, 2020 at 3:34 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
park lights are super easy.. push in the pin, and the whole stalk comes out.. once you do one, it's a walk in the park.
chev104275
Gold - Posts: 1,436
Posted: January 23, 2020 at 4:13 PM / IP Logged Link to Post Post Reply Quote chev104275
Thanks just trying to avoid a surprise in there driveway
Platinum - Posts: 7,828
Posted: January 23, 2020 at 5:14 PM / IP Logged Link to Post Post Reply Quote kreg357
Not sure if you access to DEI anymore, but they had a pretty good write-up on the modification. It is pretty easy, once you've done a few. Here is a photo of the DBALL2 instructions for a Mazda 3.
2019 Mazda CX-5, Remote Start, Parking Lights -- posted image.
chev104275
Gold - Posts: 1,436
Posted: January 23, 2020 at 6:18 PM / IP Logged Link to Post Post Reply Quote chev104275
Thanks Kreg no I don’t have access to dei anymore so that pic will come in handy
motosaki
Member - Posts: 24
Posted: January 24, 2020 at 8:26 AM / IP Logged Link to Post Post Reply Quote motosaki
super easy. done many of them, was worried about pulling the switch the first time also. just dig in you'll be fine.
15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
mgoetz74
Silver - Posts: 424
Posted: January 24, 2020 at 12:54 PM / IP Logged Link to Post Post Reply Quote mgoetz74
make sure you disconnect the battery's negative before doing RS, the keyless system in these are very easily shorted out. Probably one of the easiest cars out there if you are doing a t harness. Literately less than 15 minute install 2019 Mazda CX-5, Remote Start, Parking Lights -- posted image.
chev104275
Gold - Posts: 1,436
Posted: January 24, 2020 at 1:27 PM / IP Logged Link to Post Post Reply Quote chev104275
I’ll have to look into the t harness I usually use compustar with blade Al in it.
silvercivicsir
Copper - Posts: 416
Posted: January 24, 2020 at 3:50 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
t harness not necessary.. all the wires are in the two plugs at the start / stop module below the steering wheel. But Yes, disconnect the battery, and the Compustar / idata install is a little easier since you don't need to add extra relays VS Ds4, if you want take over.
mgoetz74
Silver - Posts: 424
Posted: January 24, 2020 at 4:13 PM / IP Logged Link to Post Post Reply Quote mgoetz74
id just do a dc3 and a t harness, done and done. You don't have to do a t harness but i like to make things simple after 20 years of doing RS's..lol
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
