2002 Ford F-150, Remote Start Problem
lt622fd
Member - Posts: 6
Posted: February 18, 2020 at 12:28 PM / IP Logged Link to Post Post Reply Quote lt622fd
Honestly, I’m trying to find out why I am unable to turn the vehicle off, using the remote while remote start is activated. One press of the RS button starts the engine. Shouldn’t I be able to turn it off with the remote? I have tried one, two, and multiple presses to do this, with no success. It doesn’t make any difference wether I lock the doors with the remote, or manually lock them. Also makes no difference which remote I use, came with 2 remotes. One remote is a 2 button( unlock and start) and the other is a 4 button (lock, unlock, start, and trunk).
Could this be a programming issue? With the “instructions “ that came with it, it says it has this capability. Everything else seems to function properly.
lectricguy
Copper - Posts: 359
Posted: February 18, 2020 at 1:11 PM / IP Logged Link to Post Post Reply Quote lectricguy
It622fd-
So the way to debug this is to strip back to the "Basic" starter connections. From your first email, you hooked up the following:
On the 5 pin harness, I connected all 5.
on the 10 pin, I connected 2, 4, 5, I believe
On the 6 Pin, I used all 6
The 10 pin connector's pin 2 (White/Blue-instant start) is not a required connection and can enable the remote start if a ground pulse is detected on the wire.
Did you disconnect the White/Blue Wire? What was the result?
Lectric Guy
djdeito
Copper - Posts: 100
Posted: February 18, 2020 at 3:46 PM / IP Logged Link to Post Post Reply Quote djdeito
have you tried holding down the remote start button for 3 seconds or more to shutdown the car?
