6 x 4 Ohm Speakers on a 2 Channel 2 Ohms Stereo Stable Amplifier
thelivingflesh1
Posted: March 14, 2020 at 7:31 PM / IP Logged Link to Post Post Reply Quote thelivingflesh1
Hello everyone.
I got a Kenwood Excelon amplifier X621 which is:
2 channel and 2 Ohms Stereo Stable / 4 Ohms Mono (Bridged) Stable
179 watts RMS x 2 at 4 ohms
305 watts RMS x 2 at 2 ohms
612 watts RMS x 1 bridged output at 4 ohm
Then i got 6 speakers JVC CS-V527(200Watt max and 27watt rms each) on 4 ohm
Need Help in:
Connecting all 6 speakers to the amplifier in such a way that the amp does not sustain damage & maximum efficiency is achieved
P.S: Dont want to add another amp as there is already one for the sub.
Thanks....Kindly tell me a diagram if possible on how to wire them all.
eguru
Copper - Posts: 340
Posted: March 15, 2020 at 11:44 AM / IP Logged Link to Post Post Reply Quote eguru
For stereo - 2 speakers in series and the 3rd in parallel. That would be 2.67 ohms.
However sound output will not be balance.
For mono make 2 strings of 3 speakers connected in series.
Connect both strings in parallel across the bridge outputs.
That would be 6 ohms equivalent.
Platinum - Posts: 13,725
Posted: March 15, 2020 at 1:09 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Parallel 3 pairs and series them. 6 ohm mono load. All 6 speakers will move the same. Above layout will have 2 moving more than the other 4. I do know about the damping factor going through the floor, but in your situation this will give you the best result.
eguru
Copper - Posts: 340
Posted: March 15, 2020 at 2:47 PM / IP Logged Link to Post Post Reply Quote eguru
If there are 3 speakers per side, connecting 2 sets of 3 speakers in series is more convenient and uses less wire.
Impedance will also be 6 ohms in bridged (mono) mode.
As mentioned, there is no suitable stereo combination.
Posted: March 15, 2020 at 9:47 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I did not see the second half of your first post.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
