2015 Nissan Rogue File for Install Remote Start Is Bad
casper2020
Posted: April 25, 2020 at 10:43 AM / IP Logged Link to Post Post Reply Quote casper2020
Hey thanks to all who help with this site. I’m trying get files or instructions to install a remote Start and when I click on the link it won’t let me opener it. Any help would be appreciaticed
Casper the friendly ghost
the12volt
Administrator - Posts: 3,959
Posted: April 25, 2020 at 10:45 AM / IP Logged Link to Post Post Reply Quote the12volt
Where is this link located?
2015 Nissan Rogue File for Install Remote Start Is Bad -- posted image. the12volt • Support the12volt.com
the12volt
Posted: April 25, 2020 at 10:47 AM / IP Logged Link to Post Post Reply Quote the12volt
I found it. The file was corrupt and has been removed.
the12volt
Posted: April 25, 2020 at 10:51 AM / IP Logged Link to Post Post Reply Quote the12volt
Here's what I have for the 2014 through 2016 Nissan Rogue
12 VOLT CONSTANT     BLUE (+)     dash fuse box, rear, white 1 pin plug, pin 1
STARTER     N/A
STARTER 2     N/A
IGNITION 1     N/A
IGNITION 2     N/A
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     N/A
ACCESSORY/HEATER BLOWER 2     N/A
KEYSENSE     N/A
PARKING LIGHTS ( - )     YELLOW USE HAZARD LIGHTS FOR NEGATIVE HOOK UP     BCM under driver dash, gray 40 pin plug, pin 11
PARKING LIGHTS ( + )     N/A
POWER LOCK     BEIGE (-)     BCM under driver dash, gray 40 pin plug, pin 10
POWER UNLOCK     LT. BLUE (-)     BCM under driver dash, gray 40 pin plug, pin 40
LOCK MOTOR WIRE     PURPLE (5-WIRE)     BCM under driver dash, brown 16 pin plug, pin 5
DOOR TRIGGER     LT. BLUE (-)     BCM under driver dash, green 40 pin plug, pin 17
DOMELIGHT SUPERVISION     LT. BLUE (-)     BCM under driver dash, brown 16 pin plug, pin 2
TRUNK RELEASE     YELLOW (-)     BCM under driver dash, green 40 pin plug, pin 16
SLIDING POWER DOOR     N/A
HORN     BEIGE (-)     driver kick, white 100 pin plug, pin 35
TACH     N/A
WAIT TO START LIGHT     N/A
BRAKE     N/A
FACTORY ALARM DISARM     PINK (DOUBLE-)     BCM under driver dash, black 40 pin plug, pin 13
ANTI-THEFT     VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE DBALL2($99) INTERFACE FOR REMOTE STARTING.
NOTES
HAS SMART KEY AND PUSH TO START REQUIRES DBALL2 INTERFACE FOR REMOTE STARTING.
Sunday, October 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
