2015 Acura TLX Base, Audio Wiring Diagram
steve350zee
Posted: June 01, 2020 at 12:38 PM / IP Logged Link to Post Post Reply Quote steve350zee
Hello,
I am looking to install subs into my Acura and am looking for a wiring diagram that has a source and remote wire. Thank you,
Steve
Platinum - Posts: 13,726
Posted: June 01, 2020 at 7:53 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If it has a factory subwoofer, The speaker wires are red - white at the amplifier behind glove box, 18 pin plug, pins 18 - 9 (w/o navi) or 9 - 18 (w/navi).
Radio 12V      Lt. Blue      +      Radio, 24 pin plug, pin 13
Radio Ground      Black      -      Radio, 24 pin plug, pin 1
Radio Ignition      Violet      +      Radio, 24 pin plug, pin 23
Factory Amp Turn-on      Lt. Green      +      Radio, 24 pin plug, pin 20
Left Front Speaker (+/-)      Brown - Yellow (preamp)      +,-      Radio, 24 pin plug, pins 14 - 15           Notes
Right Front Speaker (+/-)      Lt. Blue - Black (preamp)      +,-      Radio, 24 pin plug, pins 18 - 19           Notes
Left Rear Speaker (+/-)      Lt. Green - Blue (preamp)      +,-      Radio, 24 pin plug, pins 2 - 3           Notes
Right Rear Speaker (+/-)      Pink - Violet (preamp)      +,-      Radio, 24 pin plug, pins 6 - 7           Notes
Center Channel (+/-)      Red - Black (preamp)      +,-      Radio, 8 pin plug, pins 1 - 3           Notes
Subwoofer (+/-)      Green - Blue (preamp)      +,-      Radio, 8 pin plug, pins 5 - 7
steve350zee
Posted: June 02, 2020 at 10:00 AM / IP Logged Link to Post Post Reply Quote steve350zee
Awesome! Thanks for this info,
Just to clarify is the speaker wires at the amplifier w/o navi, 18 pin 1-9?
Also would the signal for an LOC be better pre amp or post?
Wednesday, June 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
