2004 Chevrolet Silverado, Manual to Auto Door Locks, Avital 5305L
Platinum - Posts: 7,786
Posted: July 26, 2020 at 6:20 PM / IP Logged Link to Post Post Reply Quote kreg357
I haven't seen a 5305 but if it's like other Viper units you will want to run the Black/White wire on the White 24 Pin harness to Chassis Ground to allow a R/S. Assuming your truck has an Auto Trans. Include the kit supplied switch if you want an easy Valet Mode. You could connect it to the Emergency Brake wire if you normally set the Parking Brake.
Posted: July 26, 2020 at 6:23 PM / IP Logged Link to Post Post Reply Quote kreg357
chevyboiwavy wrote:
Thank you, I have some relays coming tomorrow ill give that a try once they get here. Is it normally necessary to have to power the acc2 wire? I have seen other installs where nothing was connected to the brown wire. Is it vehicle specific or does it depend on what type of accessories package you have in your vehicle?
Pretty much depends on the vehicle. It does handle various accessory circuits. I usually power it just to duplicate a normal ignition switch sequence.
chevyboiwavy
Member - Posts: 11
Posted: July 26, 2020 at 6:33 PM / IP Logged Link to Post Post Reply Quote chevyboiwavy
Yeah my truck is automatic. I seen the valet switch but wasn't going to connect it cause there was no directions on where it goes. If i connect it to the parking brake does that mean i have to apply the parking brake in order to use the switch?
Posted: July 26, 2020 at 6:40 PM / IP Logged Link to Post Post Reply Quote kreg357
Yes, the Viper must see Chassis Ground on the Black/White wire to allow a R/S. With an A/T vehicle most installers go right to Chassis Ground. You must use the Parking Brake for a M/T vehicle.
chevyboiwavy
Member - Posts: 11
Posted: July 26, 2020 at 7:07 PM / IP Logged Link to Post Post Reply Quote chevyboiwavy
Thank you so much for you help. Now im stuck at work and cant wait to get home to wire this up.
chevyboiwavy
Member - Posts: 11
Posted: July 27, 2020 at 8:04 PM / IP Logged Link to Post Post Reply Quote chevyboiwavy
Just wanted to say thanks again I connected the black and white wire to ground and connected the relay as you said and it fired right up really apreciate the help.
Posted: July 27, 2020 at 8:20 PM / IP Logged Link to Post Post Reply Quote kreg357
Enjoy! Just in time to cool the truck down prior to entry. Man it's hot!
             2004 Chevrolet Silverado, Manual to Auto Door Locks, Avital 5305L - Page 2 - Last Post -- posted image.
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
