2010 GMC Sierra Denali, Audio Wire Diagram
kpittman216
Posted: July 04, 2020 at 2:37 PM / IP Logged Link to Post Post Reply Quote kpittman216
I'm am going to install an extra subwoofer to my Bose system that currently has a subwoofer. 1.How do I add an extra channel for the new subwoofer? And, is there an aftermarket adapter that is needed? What is the speaker wire diagram so that I know what's what?
KPitt16
geepherder
Platinum - Posts: 3,668
Posted: July 05, 2020 at 4:42 AM / IP Logged Link to Post Post Reply Quote geepherder
The wires that connect to your factory subwoofer can provide your new amplifier with signal. Many amplifiers have high level inputs which can connect directly to speaker wire. You can either use that, or you can connect a line out converter which will give you RCA outputs to connect to your new amplifier.
I don't know if your vehicle has noise cancellation, but if so you should disable it to prevent out of control rumbling from the new subwoofer.
Platinum - Posts: 13,726
Posted: July 05, 2020 at 8:45 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Amplifier is located in rear of center console.
Subwoofer (+/-)      dk blu/wht - lt grn/blk(1); dk grn - lt blu/blk(2)      +,-      amplifier, black 8 pin plg, pins 1-2; 7-3 or gray 8 pin plg, pins 7-3; 6-2
There is no Active Noise Cancelling system in that vehicle.
kpittman216
Posted: July 18, 2020 at 4:12 PM / IP Logged Link to Post Post Reply Quote kpittman216
Which wire is the ground wire
KPitt16
geepherder
Posted: July 18, 2020 at 6:18 PM / IP Logged Link to Post Post Reply Quote geepherder
Do you mean the negative speaker wire, or ground return wire?
If you're asking about the negative speaker wires, they are the ones with the black stripes.
If you are looking for a ground wire, you can just run your own.
kpittman216
Posted: July 19, 2020 at 11:07 AM / IP Logged Link to Post Post Reply Quote kpittman216
The ground return wire.
KPitt16
