Auto Start 1780, 2004 Honda Civic
hardrew_rolly
Member - Posts: 32
Posted: August 06, 2020 at 1:10 AM / IP Logged Link to Post Post Reply Quote hardrew_rolly
Hey guys,
I need help on my remote starter installation. I connected all the wire and I made it to start using the remote. The problem is whenever I start it with the remote it will start but when I insert the key and step on the brake it will activate/engage the car starter again.
I troubleshoot it and found out that the acc output from the remote starter brain causes the car starter to engage. So I disconnect it and try it without connecting the acc wire. And it work.
The problem now is how can I use the heater blower if I don't connect the acc output from the brain.
Thank you
geepherder
Platinum - Posts: 3,668
Posted: August 06, 2020 at 7:12 PM / IP Logged Link to Post Post Reply Quote geepherder
I'm assuming it's a push start, but what is the vehicle? Someone may have come across this.
hardrew_rolly
Member - Posts: 32
Posted: August 06, 2020 at 11:53 PM / IP Logged Link to Post Post Reply Quote hardrew_rolly
Sorry for not including the vehicle. It's not a push start. It's a 2004 honda civic with automatic tranny. I don't know what I did wrong. Everything works. Starter kill, brake switch. Lock, unlock, park lights.
Right now the ACC wire from remote brain is not connected to anything.
geepherder
Posted: August 07, 2020 at 6:06 PM / IP Logged Link to Post Post Reply Quote geepherder
That's odd. If there's another wire you can program as accessory, try that.
hardrew_rolly
Member - Posts: 32
Posted: August 07, 2020 at 7:47 PM / IP Logged Link to Post Post Reply Quote hardrew_rolly
What I'm planning is putting diode on the on the ACC wire from starter but I need to do a research about that. Another way is to use the 5th relay option on my remote starter brain. Which is the best option?
hardrew_rolly
Member - Posts: 32
Posted: August 07, 2020 at 9:57 PM / IP Logged Link to Post Post Reply Quote hardrew_rolly
I will use the 5th relay on my remote start primary harness. Is the 5th relay already powered? (I know it's a stupid question because I can just checked it with tester) but I'm asking it anyway. Do I need to use another relay for that? Or the 5th relay is plug and play like the other wire?
geepherder
Posted: August 08, 2020 at 8:19 AM / IP Logged Link to Post Post Reply Quote geepherder
I wouldn't know without a manual.
hardrew_rolly
Member - Posts: 32
Posted: August 09, 2020 at 2:11 PM / IP Logged Link to Post Post Reply Quote hardrew_rolly
I solved it. I used the 5th relay instead of the RS ACC wire. The manual says that 5th relay is also powered with high voltage. I test it with Multi tester and boom it has 14 volts. I hooked it up and it works like a charm.
Thank you so much.
Cheers!
