2019 Toyota Rav4, Backup Camera
bedema
Posted: August 14, 2020 at 10:51 PM / IP Logged Link to Post Post Reply Quote bedema
Hi, I am installation an aftermarket radio to my 2019 rav4. I have no idea which wire from the factory I can use. Can someone please help?
Many thanks
mgoetz74
Silver - Posts: 424
Posted: August 15, 2020 at 11:33 AM / IP Logged Link to Post Post Reply Quote mgoetz74
looks like-
video - white pin 29- cut off a spare rca and use braided part
video + black pin 28- cut off a spare rca and use solid center section and plug into aftermarket camera input
camera - green pin 27- connect to same ground as what the aftermarket radio is using
camera + red pin 30 just fyi this wire is probably only 6v so need to use a metra ax-cam6v to convert it to 6 volts, if you run 12 volts to it it will burn the camera out
Reverse Light- blue - Dash Fuse Box white 36 pin plug 4H pin 10 connect to the reverse trigger on the new radio
https://www.youtube.com/watch?v=1u7RgCnaer4
Sunday, September 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
