Automate Alarm/Remote Start, 1991 Buick Lesabre
quinny3535
Posted: September 22, 2020 at 11:38 PM / IP Logged Link to Post Post Reply Quote quinny3535
I have a 91 Buick Lesabre and I’mtrying to install a automate/directed remote start alarm I have installed alarms before but this alarm wiring diagram there is no wires for switched accessory to power the alarm all alarms I installed had a ground a constant n a accessory n I had power to the alarm I can not get any power to my alarm PLEASE HELP
geepherder
Platinum - Posts: 3,668
Posted: September 23, 2020 at 6:14 AM / IP Logged Link to Post Post Reply Quote geepherder
What is the model number of the Automate remote start unit? Is the manual in the downloads section? If not, do you have a link?
quinny3535
Posted: September 23, 2020 at 6:53 AM / IP Logged Link to Post Post Reply Quote quinny3535
It is the 1 way model 5105a I have the diagram for my car n the alarm but every alarm I installed had a 12v constant a ground and a 12v switched key it has a 2nd ignition/accessory isolation wire(87a of onboard relay) a 2nd ignition/accessory relay output (30 of onboard relay) a fused 12v ignition relay input a fused 12v 2nd ignition/accessory relay input 87 and a ignition 1 input/output
geepherder
Posted: September 23, 2020 at 9:56 AM / IP Logged Link to Post Post Reply Quote geepherder
If I understand your question correctly, you're trying to find an accessory output, correct? If it's similar to the Viper 5105 (in the downloads section), the fat orange wire (pin 8) is for accessory. Alternatively, you can reprogram the fat pink/white wire (pin 4) to accessory (default is ignition).
If you're looking for an accessory input, there isn't one, only an ignition input- the fat pink wire (which is also an output).
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
